RWD H22 project has commenced
Old Jan 26, 2004 | 06:13 AM
  #126
DaveF's Avatar
Default Re: (GITWIDIT)
wow...starting to take shape already
one question? why not build solid mounts instead of using them stock ones?
maybe 2....
how is the angle on the axles...are they straight?
Old Jan 26, 2004 | 06:46 AM
  #127
Tinker219's Avatar
Default Re: (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">wow...starting to take shape already
maybe 2....
how is the angle on the axles...are they straight? </TD></TR></TABLE>
The mounts are HCPs, for doing an H22 in the front of the car(since this is basically a front suspension setup). They dont allow much movement at all, but will "give" when I nail a pothole or something. Itll be a summer daily driver, so I dont need busted blocks from solid mounts.
The Axles arent exactly straight, but since the wheels wont be turning, I dont think itll be that large of a problem.
Ya, I was surprised how much I got done just by devoting a full day into it. Maybe Ill quit with the piddly ****, and work on it only by Sundays. At this pace, itll be done in two weeks.
Old Jan 26, 2004 | 06:48 AM
  #128
The Crow's Avatar
I can't wait to see the wheelstands this thing pulls!
Old Jan 26, 2004 | 07:16 AM
  #129
phiberoptik's Avatar
Wow.. youve mentioned this for so long its nice to finally see all your progress once you actually put your ideas to work.
Props on it man!!
btw.. you dont look anything like I imagined. hahaha
Old Jan 26, 2004 | 07:19 AM
  #130
Tinker219's Avatar
Default Re: (phiberoptik)
Ya, Im 5'8", 170 lbs. Just a punk kid!
Old Jan 26, 2004 | 07:23 AM
  #131
no i pictured 5'8", 150lbs, couldnt grow facial hair if he tried... lol
basically you arent as young looking as I imagined.. hahahaha
Old Jan 26, 2004 | 07:26 AM
  #132
Tinker219's Avatar
lol, i get offered to be served beer ALL the time. I dont drink though, so I decline anyway(and theyd ask for ID, which theyd find that Im only 20).
Old Jan 26, 2004 | 07:44 AM
  #133
gitwidit's Avatar
Default Re: (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">I dont drink though</TD></TR></TABLE>
:cough: Bullshit :cough:
Old Jan 26, 2004 | 07:49 AM
  #134
speaking of... wanna go get a beer sometime craig??
cody.. you can come down too.. lol and bring my sst
Old Jan 26, 2004 | 08:39 AM
  #135
colt45.5's Avatar
Craig only drinks O'Douls. Hes a fah-china.
Haha.
Old Jan 26, 2004 | 01:04 PM
  #136
Buraku's Avatar
Default Re: (colt45)
problems I forsee:
- intake manifold clearance with strut tower brace.
- exhaust manifold / turbo placement with that metal bar in the way.
- axles angle looks WAY fucked. I forsee massive axle failure if that tire is where the hub is.
- appears you are using the entire front suspention assembly which means ball joints on the hub. How do u plan to keep the wheels str8 w/out mkaing the car AWS? If you do this wrong, the car will suffer from bump steer.
Old Jan 26, 2004 | 03:23 PM
  #137
H22A EG6's Avatar
Default Re: (Buraku)
i cant stop drooling
Old Jan 26, 2004 | 03:30 PM
  #138
gots_a_sol's Avatar
make me want to break out the welder and such!
Old Jan 26, 2004 | 03:39 PM
  #139
GOTNOS's Avatar
when its done ill buy it
Old Jan 26, 2004 | 03:52 PM
  #140
Hoosier Daddy's Avatar
Default Re: (GOTNOS)
looking good
Old Jan 26, 2004 | 04:19 PM
  #141
gots_a_sol's Avatar
nice jackstands
Old Jan 26, 2004 | 04:28 PM
  #142
JrCRXHF's Avatar
Default Re: (Couto)
it does not look like the drive shafts are going to line up i know it is only a pic and it might just be the angle but what are you going to do for rear uprights just take the front ones and hold the steering inputs soild???? just kinda wondering
Old Jan 26, 2004 | 04:36 PM
  #143
chidoks's Avatar
nice cody...hurry up and finish this so we can do mine next...
Old Jan 26, 2004 | 04:48 PM
  #144
LSTEG96's Avatar
Default Re: RWD H22 project has commenced (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I ******* hate you. </TD></TR></TABLE>
Old Jan 26, 2004 | 05:45 PM
  #145
EF'n's Avatar
Default Re: RWD H22 project has commenced (LSTEG96)
the axle location is as was taken directly from where the hcp mounts put the h22 and axles in the front. it worked fine at that angle in the front, dont see any reason to think it will work any different in the rear.
Old Jan 26, 2004 | 06:45 PM
  #146
redlineb18's Avatar
Default Re: RWD H22 project has commenced (revhardracing)
This monster is definately coming along. Seeing it in my brother's garage makes me wet I just can't wait until spring...
keep up the good work bro
Old Jan 26, 2004 | 08:13 PM
  #147
paulzy's Avatar
Nice **** Cody...coming along great...
one complaint though:
get some jackstands under that car. I'd hate to see what would happen to that car or the person that under it when the blocks finally give way to the weight
Old Jan 26, 2004 | 08:29 PM
  #148
95IntegraGSRAZ's Avatar
Default Re: (Paul_Vang)
Good luck guys....
Do you think it will have a much better 1/4mi. time as a delsol with the same engine and mods but stock FWD....thats most likely why your doing this whole project, but I am just curious?
Old Jan 26, 2004 | 08:45 PM
  #149
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">- appears you are using the entire front suspention assembly which means ball joints on the hub. How do u plan to keep the wheels str8 w/out mkaing the car AWS? If you do this wrong, the car will suffer from bump steer.</TD></TR></TABLE>
What have you worked out for this suspension part Cody? Heim Inner TRE and stock outer TRE right? how long will they be, same as the stock ones?
Old Jan 26, 2004 | 08:49 PM
  #150
hybrid93SIvic's Avatar
Default Re: (Bailhatch)
bumping it up again...i would also like to know a lot of the answers to these questions
