RWD H22 project has commenced
Old Jan 27, 2004 | 07:52 PM
  #176
HaTcH_BmX's Avatar
Default Re: RWD H22 project has commenced (Tinker219)
i just talked to jessie james, he wants you in his monster garage next episode. lol
dude, mad props to you.
Old Jan 27, 2004 | 07:59 PM
  #177
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, I just walked outside from being in the shop since 4pm, and the Peon is COMPLETELY burried. Only vids youll see is of me rolling out the door, and dissappearing into a snow bank taller than the car.
Plus, I dont have a working engine yet either. Jen(my gf) owes me a sleeve job and some rods, so as soon as she coughs up the $, Ill have a running RWD del sol </TD></TR></TABLE>
sleeve job and a rod job, eh?
Old Jan 27, 2004 | 08:01 PM
  #178
DaX's Avatar
DaX
Loved
Community Favorite
She blew his "motor."
Old Jan 27, 2004 | 09:38 PM
  #179
Kwuaymaikrup's Avatar
Default Re: RWD H22 project has commenced (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">true i didnt think about that. are you gonna get a quaife?</TD></TR></TABLE>
Probrably just gonna weld it up. No more worrying about the welds breaking since the wheels don't have to steer.
-Ryan
Old Jan 28, 2004 | 12:06 AM
  #180
ImportHatch's Avatar
Default Re: RWD H22 project has commenced (Kwuaymaikrup)
Looks sweet, cant wait to see new pics.
Yager-
Old Jan 28, 2004 | 04:27 AM
  #181
Tinker219's Avatar
Im going to debate this issue a lil bit. Since it WILL be a DD, I dont need useless **** breaking. Ill just be using an Accord tranny because of the extremely high gearing(2200rpm at 65mph), I like that, less stress on the engine. Welding the diff MAY still be a temporary option though, I can always pull it out and swap for a $900 quaife later on...
Old Jan 28, 2004 | 05:04 AM
  #182
Buraku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
-Ryan</TD></TR></TABLE>
You may want to think about this a little harder
Old Jan 28, 2004 | 05:59 AM
  #183
Scott - 93HB Si's Avatar
Default Re: RWD H22 project has commenced (Buraku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">
You may want to think about this a little harder </TD></TR></TABLE>
Exactly! there's a reason guys with RWD cars don't weld their diffs either!
Old Jan 28, 2004 | 01:34 PM
  #184
TerribleOne's Avatar
Default Re: (civicvteckid)
wow awsome keep going! Im subscribing to this thread!
Old Jan 28, 2004 | 01:36 PM
  #185
Tinker219's Avatar
Default Re: (TerribleOne)
If I get done whats on my list for the day, ill have pics of a started(maybe completed) Intake manifold tonight....
Old Jan 28, 2004 | 02:13 PM
  #186
kpt4321's Avatar
Couple of things:
The suspension mount looks good, but you might want to consider triangulating it with that piece above it. As a matter of fact, I would say you definately should. There's a lot of load on those mount points, and the way it's set up now it will all be torque on that mount point.
You might want to reconsider gearing the car that low. 2200 rpm at 65 mph is REALLY low, especially for a 4 cylinder motor with a big turbo. If you're closer to 2500 at 65, it won't take you 3 downshifts to get spool out of it.
Just something to consider.
I wouldn't lower it too much. I think that with the tops of the tires around the fenderwells (where they are in that picture, or hopefully even less tucked) is where you want to be on a street car. From my experience, even with really stiff springs you're going to be unhappy with a car that low, especially since you're trying to make it a daily driver.
Old Jan 28, 2004 | 08:45 PM
  #187
Tinker219's Avatar
Default Re: (kpt4321)
Ya, Ill be running alot more braces once I get the final setup figured out(ie, turbo, build the manifold, and WAIC).
Im just going to have to get some TEINs or something, then I can pretty much do what I wish!
Got the IM mostly done. I hit a "dirty spot" in the AL, and called it quits for the day. Its very frusttrating when you weld for 45 min, and only go a half inch.
Old Jan 28, 2004 | 09:26 PM
  #188
JonGP4's Avatar
Default Re: (Tinker219)
i drive an accord daily, the gearing isn't that low.. at 65 with 205/55 r15s the rpms are closer to 2600.. at 60 i know i'm at 2400, at 80 i know i'm at 3200.. but yeah, the accord trany sucks.. throws syncro's all the time and won't hold up to long under a turbo.. i'd go with a h23a trany..
Old Jan 29, 2004 | 12:38 AM
  #189
Default Re: RWD H22 project has commenced (Scott - 93HB Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott - 93HB Si &raquo;</TD></TR><TR><TD CLASS="quote">
Actually I know of quite a few people with rear wheel drives that don't break the welds. Although, they don't drive them all that often and it isn't the best way it IS possible. If it used for a track car I see no reason why it wouldn't last. As far as Cody's is concerned I was assuming it would see a fair amout of street time and it seems to be the most cost effective way to prevent the guaranteed peglegs he will see. I am sure he will take care of it. No need to throw the It was just a thought.
-Ryan
Old Jan 29, 2004 | 04:35 AM
  #190
Tinker219's Avatar
Ya, RWD peg legs are just as unimpressive as FWD ones. lol...
Still a thought, I need to gather more info. The axles I will be using will take it no problems, its whether or not the rest of the chassis/tranny will hold.
Old Jan 29, 2004 | 02:35 PM
  #191
H22A EG6's Avatar
i cant wait to see what that bad boy runs
Old Jan 29, 2004 | 02:45 PM
  #192
hybrid93SIvic's Avatar
Default Re: RWD H22 project has commenced (H22A EG6)
bumpin it up once again
Old Jan 29, 2004 | 03:57 PM
  #193
kfar09's Avatar
congrats man. this is going to be one amazing car. when you get done, we can start in on my car. haha
can't wait to see more pics. looks like you REALLY know your ****
Old Jan 29, 2004 | 04:01 PM
  #194
buck02's Avatar
Default Re: (kfar09)
cody i think you need a build h22 to put in there hit me up in 2 days k i got other very interested k
Old Jan 29, 2004 | 04:17 PM
  #195
DaX's Avatar
DaX
Loved
Community Favorite
Cody, is it a figment of my imagination, or did I talk to you a few months ago and you mentioned something about building a twin engine [h22] del sol? Is that what this project originally started out as?
Old Jan 29, 2004 | 04:29 PM
  #196
SleepyEG's Avatar
Default Re: (DaX)
Complete side note for Dax...nice essay. I'm assuming you wrote that? Where are you at school? I noticed your only reference as a book by Norton..I'm an ME major at WPI, this is where he teaches. He's done some cool stuff. At different points he has attempted to build both ceramic valves, and ceramic bearing turbos. Very cool guy.
~james
Old Jan 29, 2004 | 04:46 PM
  #197
DaveF's Avatar
i would most definitly add some braces to this....like a diagonal going from the smaller "lower tube" to the larger "upper tube" to create a triangle in a sence...and maybe even weld tabs onto it, so you can fabricate a strut tower brace to connect both shock "towers..than the tabs will be there to mount the strut tower brace.
Old Jan 29, 2004 | 04:54 PM
  #198
SleepyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote"> i would most definitly add some braces to this....like a diagonal going from the smaller "lower tube" to the larger "upper tube" to create a triangle in a sence...and maybe even weld tabs onto it, so you can fabricate a strut tower brace to connect both shock "towers..than the tabs will be there to mount the strut tower brace.</TD></TR></TABLE>
already asked...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">The suspension mount looks good, but you might want to consider triangulating it with that piece above it. As a matter of fact, I would say you definately should. There's a lot of load on those mount points, and the way it's set up now it will all be torque on that mount point.
and answered
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Ya, Ill be running alot more braces once I get the final setup figured out(ie, turbo, build the manifold, and WAIC).
Didn't mean that in a mean way, just trying to save Tinker from having extra typing, he's already got enough work to do!
Old Jan 29, 2004 | 08:11 PM
  #199
Default Re: (SleepyEG)
once again and again...back up
Old Jan 29, 2004 | 08:31 PM
  #200
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyEG &raquo;</TD></TR><TR><TD CLASS="quote">Complete side note for Dax...nice essay. I'm assuming you wrote that? Where are you at school? I noticed your only reference as a book by Norton..I'm an ME major at WPI, this is where he teaches. He's done some cool stuff. At different points he has attempted to build both ceramic valves, and ceramic bearing turbos. Very cool guy.
~james</TD></TR></TABLE>
Thanks for the compliment! I'm an ME major at Georgia Tech. Yeah, that was my final project for my Dynamics of Rigid Boides class last semester. I wanted to use other references, but Norton did such a great job with that book, it was all I needed! I'm glad someone appreciates that essay...I tried posting a thread but only got like two half assed "cool man" responses. Norton definately knows his ****...that book was interesting. Did he have any success in building those ceramic valves?
//end hijack thread
I guess PM me so we don't have to hijack this thread any more.
