running a built motor with no turbo? safe??
okay I am ready to drop my built motor in my teg and I was wondering if it would be safe to run it with out the turbo for a while and what the safest way would be?? the motor that is coming out of the car is a lsvtec as well so could i just drop in my new motor and run it with the same ecu that my car already has or would it still need to be tuned even though i am not going to run the turbo yet??
-dan
-dan
Re: running a built motor with no turbo? safe?? (dansred2000si)
Of course it would be safe. Why would having a turbo on it (or not) make it any safer? If the engine you have is built for turbo (with a lower c/r), then it just means that your motor is gonna feel a little on the slow side. SOB will last FOREVER, but it will feel sluggish.
so do I run it with the same stock ecu that the car has already or do I still have to have it tuned?? I am just not quite ready to throw in the turbo right now until early next year so I want to run it without the turbo for now.
Re: (dansred2000si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dansred2000si »</TD></TR><TR><TD CLASS="quote">so do I run it with the same stock ecu that the car has already or do I still have to have it tuned?? I am just not quite ready to throw in the turbo right now until early next year so I want to run it without the turbo for now. </TD></TR></TABLE>
You will have to tune this motor from the start if you want it to last.
Re: (OMG B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG B16 »</TD></TR><TR><TD CLASS="quote">
You will have to tune this motor from the start if you want it to last.</TD></TR></TABLE>
You serious? its a built motor with no turbo on it, its going to be the same as stock with a little bit lower compression, there is no problem with driving it as is.
Re: (AaronJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ »</TD></TR><TR><TD CLASS="quote">
You serious? its a built motor with no turbo on it, its going to be the same as stock with a little bit lower compression, there is no problem with driving it as is.</TD></TR></TABLE>
100% agree
100% agree
stocker2shocker91
07-14-2010 03:54 PM
jimjam187
03-06-2008 06:30 PM
redcivic44
02-06-2006 05:33 PM
