randomly leans out at light throttle
Old Jul 21, 2012 | 10:11 AM
boosteddohczc's Avatar
Default randomly leans out at light throttle
ok so i have a 93 civic with a built b16 turbo tuned on crome pro. runs great but randomly at light throttle it will lean way out and obviously not wanna go anywhere till i give it more gas then its fine again. air fuels are fine everywhere else all the way till 8500 rpm's at 20 psi. So i hooked my tuning stuff up and was watching the air fuels and looking at the map. finally i got it to do it so i added more fuel and it seemed ok again. then later that night it started doing it again and when it wasnt doing it it was a lil rich cuz i had added fuel there.
i changed the cap, rotor and plugs. still does it. changed and adjusted the tps and it still does it. wtf is going on. it seems like it started doing it after i hooked mt aem wideband up as the o2 sensor. in the settings of crome i switched it over to the aem widband. ive done this on other cars and didnt have a problem so i don't know whats going on. does anyone have any ideas of what this could b because its really annoying when im trying to stay at a steady speed. either i have to give it more gas so it doesnt do it but then i end up speeding or i have to let off n hit the gas again.
Old Jul 21, 2012 | 10:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: randomly leans out at light throttle
Hm. Although you're in the wrong forum I'll take a stab at this.
Worked fine BEFORE the AEM as the O2. Does not work so well AFTER the AEM as the O2. Lemme guess. The AEM is your problem.
Old Jul 21, 2012 | 10:37 AM
Dc4LsTeG's Avatar
EK9
Is this happening while in closed loop?
Old Jul 21, 2012 | 10:41 AM
The Grumpiest
He stated it was random. I would like to know exactly what "leans out" means in numbers.
Old Jul 21, 2012 | 10:47 AM
Dc4LsTeG's Avatar
EK9
I took it as it was leaning out passed what the gauge could read. If its just happening randomly and not every time your at the same load and rpm, maybe your sensor is going bad.
Old Jul 21, 2012 | 01:31 PM
ok it just droppes off the scales lean when it happens. the aem sensor reads fine thats not the problem. when it does this it stumbles and acts like i turned the key off but kept on the gas. then when i give it more gas the air fuels go back to normal and it runs fine. and like i said ive ran aem widebands as o2 sensors in tons of other cars and it didnt do this. its in open loop so that it can read the sensor as a o2. when i tune it i put it in closed loop but the whole point in having it enabled and running as a o2 senso is so it can calculate for different temps n humidity's. has anyone had this problem?
Old Jul 21, 2012 | 01:33 PM
Dc4LsTeG's Avatar
EK9
Sorry but isn't it supposed to be reading it as an o2 in closed loop and shouldn't you be tunning in open loop?
Old Jul 21, 2012 | 10:00 PM
ralph11sec's Avatar
leave the setting in open loop.
make sure the numbers dont jump. try to make the adjustments gradual as possible.
do not target to make 14.7 in every cell. most cell is fine as long as the fuel curve is not a mess.
make sure ign curve is not messed up too.
check you fuel multipliers againts ect/iat/batt/vss/tps/etc
Old Jul 21, 2012 | 10:07 PM
EF9_TryMe's Avatar
Exhaust leak after the hot side during closed loop ?
Old Jul 23, 2012 | 08:02 PM
well i disabled it and it doesn't do it anymore.
boosted199
Apr 23, 2016 06:33 PM
SiRCiviC94
Aug 1, 2014 06:47 PM
wilham320
11
Feb 24, 2007 03:07 AM
DurboDug93
May 14, 2005 08:01 PM
pornstarSR
Jun 5, 2004 01:15 PM
