B16T dumping fuel off throttle
Old Jul 29, 2014 | 08:56 PM
SiRCiviC94's Avatar
Default B16T dumping fuel off throttle
Random issue, up until a week ago my car ran great it's a stock b16 on 10psi tuned on chrome.
The issue is not always happening sometimes it's back to perfect. So Normally off the throttle means no fuel is going in , wideband 18+, When I give it some light boost or sometimes normal driving and let off its burps and pops wideband flashing 10-12:1-18+ it won't stay off the gas. Back on the gas numbers are ok. Sometimes they aren't and jumping. Next I'll go and be idleing the car suddenly dumping 10:1 until I wait or rev it till it figured out wtf .
Like I said this just came up, changed plugs cleaned tb swapped map sensors. Injectors cleaned last season 680cc.
It's a drivability issue flooring it is totally fine.
Next step? This is preventing some racing I'd like it sorted out. Compression timing everything is good. Tps? I will check.
Old Jul 30, 2014 | 05:39 AM
Muckman's Avatar
Moderator in Chief
Default Re: B16T dumping fuel off throttle
Its the decel parameters. Contact your tuner.
Old Jul 30, 2014 | 05:58 PM
SiRCiviC94's Avatar
this would change after 2 years no problems? it happens at idle sometimes as well, and sometimes the driving is not good either. it effects the entire operation at partial throttle. I cant figure it out. problem is intermitent
last hope is the tune shop
Old Aug 1, 2014 | 06:11 AM
SiRCiviC94's Avatar
Tps wire broke.
Old Aug 1, 2014 | 02:13 PM
wantboost's Avatar
Who is Mr Robot?
yea it would either be the tps or decel fuel fut was somehow turned off in the ecu
Old Aug 1, 2014 | 04:30 PM
SiRCiviC94's Avatar
Yuuuup a good old t tap from my nitrous days was the culprit . Car runs great again. I'm using a tb without a fitv now since I swapped it to troubleshoot I guess it doesn't matter
Old Aug 1, 2014 | 04:31 PM
SiRCiviC94's Avatar
That coulda cost me a run
Old Aug 1, 2014 | 05:24 PM
turbohatch96y7's Avatar
Whats the setup?
Old Aug 1, 2014 | 06:47 PM
SiRCiviC94's Avatar
stock b16 57 trim
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
elnene_14
Aug 25, 2013 10:55 AM
NemesisCBR
May 9, 2012 06:21 AM
rolledthatho
Feb 20, 2011 05:58 AM
bigempty12
Nov 26, 2007 06:17 PM
