Question please help
Old Aug 19, 2004 | 05:13 PM
TURBODC4TEG's Avatar
Default Question please help
ok harry at precision told me to run an oil filter relocation kit so the oil gets filtered before it goes into the turbo. Reason being is i keep getting metal in my turbo and tearing them up. i am using the golden eagle adaptor for the feed line to the turbo, does anyone know if the oil goes to the filter then to feed off the golden eagle? i have recently cleaned all of it out hopefully and need something like a inline oil filter or something to filter the oil before it goes into the turbo plz help
oh i searched btw didn't find anything
Old Aug 19, 2004 | 06:25 PM
Default Re: Question please help (TURBODC4TEG)
bump
Old Aug 19, 2004 | 07:32 PM
someone??
Old Aug 19, 2004 | 07:43 PM
Bailhatch's Avatar
well ya, a filtered oil source will keep metal out of your turbo. what about the engine that is making these metal flakes? that's what I would be worried about.
Old Aug 19, 2004 | 07:57 PM
Default Re: Question please help (Bailhatch)
well harry said it was a piece of steal as a cam shaft or crank
i didn't find any, i have taken off my oil pan 4 times and cleaned and it i don't see any metal flakes or anything just don't want to take a chance
Old Aug 20, 2004 | 09:38 AM
bump
someone? does the golden eagle adaptor filter oil before it goes through the lines?
Old Aug 20, 2004 | 10:35 AM
adseguy's Avatar
If you are getting that much flaking that you need to filter it out, I'm more worried about your engine. Are you breaking in a motor? It's not good to have that much metal shaving on a broken in engine. The oil filter should be very sufficient. Fix your motor first!
Old Aug 20, 2004 | 11:02 AM
Default Re: Question please help (adseguy)
thats the thing its stock less then 90k on it, bearings are good, compression is good, cams etc
i think it was from the golden eagle adaptor, they are cnc machined and arent cleaned out thats where i think the shavings came from
Old Aug 20, 2004 | 03:31 PM
up
Old Aug 20, 2004 | 10:42 PM
wonderful help i'm getting help plz
Old Aug 21, 2004 | 09:05 AM
adseguy's Avatar
The thing with your question though is you have a very unique problem. No one spits out so much metal in their oil that they need a seperate filter. You have a problem with your car and you just want to use a bandaid to fix it. Fix you engine and then you won't need this oil filter.
firewall
Dec 15, 2017 11:53 AM
dungsta
Honda Civic (2006 - 2015)
Dec 24, 2013 12:58 PM
kmaz93da
Jun 30, 2010 01:12 AM
HighRevn
Oct 19, 2006 04:43 PM
Rod.
Aug 10, 2005 05:34 PM
