Question please help
ok harry at precision told me to run an oil filter relocation kit so the oil gets filtered before it goes into the turbo. Reason being is i keep getting metal in my turbo and tearing them up. i am using the golden eagle adaptor for the feed line to the turbo, does anyone know if the oil goes to the filter then to feed off the golden eagle? i have recently cleaned all of it out hopefully and need something like a inline oil filter or something to filter the oil before it goes into the turbo plz help
oh i searched btw didn't find anything
well ya, a filtered oil source will keep metal out of your turbo. what about the engine that is making these metal flakes? that's what I would be worried about.
well harry said it was a piece of steal as a cam shaft or crank
i didn't find any, i have taken off my oil pan 4 times and cleaned and it i don't see any metal flakes or anything just don't want to take a chance
If you are getting that much flaking that you need to filter it out, I'm more worried about your engine. Are you breaking in a motor? It's not good to have that much metal shaving on a broken in engine. The oil filter should be very sufficient. Fix your motor first!
thats the thing its stock less then 90k on it, bearings are good, compression is good, cams etc
i think it was from the golden eagle adaptor, they are cnc machined and arent cleaned out thats where i think the shavings came from
The thing with your question though is you have a very unique problem. No one spits out so much metal in their oil that they need a seperate filter. You have a problem with your car and you just want to use a bandaid to fix it. Fix you engine and then you won't need this oil filter.
dungsta
Honda Civic (2006 - 2015)
Dec 24, 2013 12:58 PM
