question for any h22a4's woth turbo
New User
does any1 here run a turbo with an internal wastegate? and if so what manifold did you chose and did the turbo and wastegate fit properly? if im running at least 6 psi daily in a 5th gen lude with stock internals to start out. what else do i need besides the obvious. so far i have the t3 turbo with an internal wastegate, the intercooler, boost gauge
the things i know i need to get also is the manuel boost controller, fuel pump, IC piping, BOV, and FMU. with stock injector whats FMU do you think is best? also which fuel pump is the one i need for the 5th gen lude, intake or inline?
** need some help to gte the boost loose in the 5th gen lude**
wes7side5o
02-14-2006 12:40 AM
