2nd gen eclipse t25, possible to run less than 11lbs??
Is it possible to turn boost below 11lbs on a t25 eclipse turbo? I know stock they run 11lbs and was wondering if the wastegate is set at 11 or what? Friend needs to know bc hes making a homemade kit. He has a boost controller already, but isnt sure if the turbo will go below 11, thanks
Re: 2nd gen eclipse t25, possible to run less than 11lbs?? (Casey)
the wastegate is set at 8 psi. fatory from eclspise is 11-12 because they have a boost controller on there stock.
superhatchbackbros
06-30-2007 09:17 AM
T-RO
06-28-2004 04:16 PM
