which turbo for me???
Old Mar 7, 2004 | 07:32 PM
vteckiller's Avatar
Default which turbo for me???
well I have parted everything else together and still need help on choosing my turbo. It is between the sc34 or sc61. how much difference will it be for full boost? Ive read that the 61 makes full boost on b16's at5000- 5100 but what about on a b18c5? Would it be a liitle less or no? Will the sc61 be too much with this set up or just right? It will all be on stock internals. I am planning on running 12psi daily and 15psi for track. hp goal is around 325-350 for know until i rebuild bottom end. Im just worried about going to big on turbo. The car also will be daily driven. Thanx
sc34 or sc61 precision turbo?????
inline pro log mani
custom 2.5 in dp
inline pro intercooler piping
tial 38mm wastegate
hks ssq bov
precision 31.5x8.0x3.5 fmic
rc 650cc sat inj w obd2 clips
walboro 255lph in tank fuel pump
cometic headgasket (.057in)
hondata s200b p28 ecu
cm stage 4
Old Mar 7, 2004 | 08:07 PM
Muckman's Avatar
Moderator in Chief
Default Re: which turbo for me??? (vteckiller)
Judging from your goals I would think a medium sized T3/T04 turbo such as the SC34 would be ideal. I have the same power goals as you and thats what I chose for my GSR.
Old Mar 7, 2004 | 08:30 PM
vteckiller's Avatar
Default Re: which turbo for me??? (Muckman)
thanx. but how much hp would i be making on the sc34 at 12 pds compared to the sc61 at 12 pds
Old Mar 7, 2004 | 08:33 PM
TurboJesse
Guest
Posts: n/a
throw out the idea that you have to limit yourself to 12psi. you say you want 325-350whp. Either turbo can do that. It might take a few more lb's to reach it with the sc34 but you will have a more useable powerband.
Old Mar 7, 2004 | 08:39 PM
slim9300's Avatar
More dispacement= more exhaust gas= faster spool
That should answer your question about b16 versus b18 spool times.
If I had to guess the difference it would be 300-500 RPMs earlier with the 1.8L as comapred to the 1.6L
NBPdEeCeE
Aug 17, 2007 01:12 PM
2-7offsuit
Sep 30, 2005 04:05 PM
xxredpreludesixx
Jun 10, 2005 09:24 AM
19sec beast
Mar 20, 2005 06:50 AM
dvtlegend
May 3, 2004 05:12 PM
