Q about compression ratios
Old Aug 23, 2003 | 12:23 PM
dtec's Avatar
Default Q about compression ratios
i am going to sleeve my block with 9.0:1 pistons soon, and i have a question. i plan on going turbo in the future, but not near future. am i going to loose power with the new pistons since i am still N/A for a while? because i think for N/A cars, higher compression is better, right? should i just wait until i turbo to sleeve and install the pistons?
Old Aug 23, 2003 | 01:37 PM
VTEC-DA's Avatar
Default Re: Q about compression ratios (dtec)
Yes, you will lose power dropping the compression while staying N/A.
Old Aug 23, 2003 | 01:41 PM
RenoRacing's Avatar
Default Re: Q about compression ratios (VTEC-DA)
You have to break in any freshly sleeved and assembled motor. Stock ls's are only like 9.5:1 so it won't be much worse than that. I wouldn't let it stop you from sleeving right now. It's better to have that broken in and ready to go when your turbo setup is.
Old Aug 23, 2003 | 02:26 PM
t616
Guest
Posts: n/a
Default Re: Q about compression ratios (HavokRacing)
might as well sleeve a block and have the rods/pistons installed and break it in then save more for the turbo kit/parts afterwards.
trav39562
Mar 31, 2009 04:39 PM
allmotorpackage
Nov 9, 2008 11:38 PM
lsturbo*
Sep 16, 2006 05:24 PM
jdmcivic1999
Aug 19, 2005 06:35 PM
