Pushing the 18G
Old Sep 29, 2005 | 11:56 PM
  #76
Maxime's Avatar
I see 9psi around 4200-4300 rpm on my car.
At least I think I do. Im gonna have to check to make sure.
Old Sep 30, 2005 | 12:12 AM
  #77
avex's Avatar
Default Re: (urbansi)
Recent dyno (1bar)
old dyno (same 1bar)
I dont know what it could be. The differences in this setup from my previous is:
83mm instead of .20
built block (sleeves,rods, 9:1 pistons)
itr 98 spec intake cam (old was stock b16 cam)
turboxs dual stage boost controller (old was apexi avc-d)
Neptune (s200b old)
Stock cat (old was dynoed using a test pipe)
my old greddy kit was awesome, i shouldn't have sold it. This new one is eh wtf.
Old Sep 30, 2005 | 03:54 AM
  #78
1sikhatch's Avatar
Do u guys have pics of ur setups?
Old Sep 30, 2005 | 04:40 AM
  #79
blaze the chemi's Avatar
Mine is huge like BoostR41. This was done recently. Something is up with the ignition up top, but that's a different topic.
I see boost hitting just over 2500 and I am at full boost (11 psi) by 4500, give or take a few 100 rpms
Setup:
B16A
9.9 SRP Pistons
Crower Rods
ACL Bearings
ARP head studs
OEM Head gasket
Skunk2 Cam Gears
550 RC's
MSD 6A w/ Blaster SS coil
FMIC w/ Blitz BOV
Greddy 18G kit
Greddy MBC
AEM EMS
Old Sep 30, 2005 | 05:36 AM
  #80
b00sted4dr's Avatar
Default Re: (avex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avex &raquo;</TD></TR><TR><TD CLASS="quote">Recent dyno (1bar)
83mm instead of .20
Neptune (s200b old)
my old greddy kit was awesome, i shouldn't have sold it. This new one is eh wtf.</TD></TR></TABLE>
Wow, that is a big difference. Might be the stock cat.
Old Sep 30, 2005 | 08:18 AM
  #81
LoSt is BlaCk's Avatar
Default Re: (b00sted4dr)
good stuff
Old Sep 30, 2005 | 11:59 AM
  #82
GPNY's Avatar
Default Re: (LoSt is BlaCk)
I soon intend to be selling an internally gated T25 flanged 10CM Housing.
3 bolt discharge...
I got it from Japan.
This would allow people to replace the greddy housing and make a custom DP...
PM offers...
Old Sep 30, 2005 | 12:09 PM
  #83
BoostR41's Avatar
Default Re: (GPNY)
mitsu or nissan T25 flange?
Old Sep 30, 2005 | 04:41 PM
  #84
GPNY's Avatar
Default Re: (BoostR41)
Nissan T25 flange. Same flange as greddy.
3 bolt outlet
Old Sep 30, 2005 | 09:32 PM
  #85
JDMorgan's Avatar
Default Re: Pushing the 18G (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">Planned set-up:
j.e or wisco pistons 9.1 CR
eagle h-beam rods
walbro 255
acl bearings
oe head gasket
ARP headstuds
dsm 450's with resistor box
kteller 2.5inch dp
port wastegate
stock crank, cams/head
fpr
gm 3-bar
oil oressure gauge and egt gauge
re-tune uberdata
i am sure i am missing a few things here and there
i figure that the whole build with tune will cost around $1600-1900, with me putting the motor together.
300whp posssible if not tell me what your opinions are. Thanks </TD></TR></TABLE>
i would just pickup a b18c1 block, and cams for your b16 setup. then buy an oem honda headgasket w/ aebs head studs + blox intake manifold, gm 3 bar map sensor, walbro 255 fuel pump, rc 440 injectors so you don't need an impedance box.
now you got the big stuff done, pickup a greddy exhaust manifold, turbo, and exhaust elbow, then go for the kteller downpipe. you still would need an ic, piping, bov, + oil lines, but that just gives you an idea of a setup that would be good for what you want. exhaust + intake are really up to you, but make sure you have a fairly large filter. you can actually use an aftermarket intake for a 1st gen dsm sometimes.
Old Oct 1, 2005 | 06:32 AM
  #86
urbansi's Avatar
Default Re: Pushing the 18G (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote"> pickup a greddy exhaust manifold, turbo, and exhaust elbow, then go for the kteller downpipe. you still would need an ic, piping, bov, + oil lines, but that just gives you an idea of a setup that would be good for what you want. exhaust + intake are really up to you, but make sure you have a fairly large filter. you can actually use an aftermarket intake for a 1st gen dsm sometimes. </TD></TR></TABLE>
i have all those things already installed on my car aside fomr the injectors. a C1 block would be nice but i dont really have the time nor money to put together a bare short block
Old Oct 2, 2005 | 01:02 PM
  #87
urbansi's Avatar
bump for more setups
Old Oct 2, 2005 | 09:04 PM
  #88
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">i have all those things already installed on my car aside fomr the injectors. a C1 block would be nice but i dont really have the time nor money to put together a bare short block </TD></TR></TABLE>
good call, buy mine.
Old Oct 2, 2005 | 09:14 PM
  #89
urbansi's Avatar
good call, buy mine. </TD></TR></TABLE>
Old Oct 2, 2005 | 11:53 PM
  #90
btotherizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">bump for more setups</TD></TR></TABLE>
Making 345whp and 248flbs on a clayton 4wd dyno at 17-18 psi on a itr with 9:1 arias and eagle rods, hondata, 680cc's, turbosmart external wastegate welded onto the greddy mani. No traction before 3rd gear. Internal wastegate sucks. i had major problems made the switch and i couldn't be happier.
Old Oct 3, 2005 | 02:26 AM
  #91
fkneh's Avatar
Default Re: Pushing the 18G (btotherizzle)
okay I have a mitsu TDO5 small 16G. A guy in my area is selling a 18G with no exhaust housing for really cheap like $100. Should I pick up the 18g and use the 16g exhaust housing?
Where is a good place to buy a equal length manifold for it?
btw I have a gsr
Old Oct 3, 2005 | 10:18 AM
  #92
93si-hybrid's Avatar
Whats a good housing to upgrade to?
Old Oct 3, 2005 | 10:49 AM
  #93
urbansi's Avatar
Default Re: (93si-hybrid)
not too sure about the housing.
as for the equal lenth manifold i looked into doing it but it ended up being way too expensive. all you need for an EL is a t-25 flanged turbo manifold.
Old Oct 3, 2005 | 11:10 AM
  #94
YashiMotors's Avatar
How stable are your boost guys when running so much boost as 20Psi on these turbos? Does it stay at 20Psi all the way up?
Anyone tried Volvo/Mitsu turbos?
Old Oct 3, 2005 | 02:09 PM
  #95
ITSME4G63's Avatar
Default Re: (YashiMotors)
here is a flow map for the td05 18g
http://www.stealth316.com/imag...c.gif
you can keep the turbo in its highest efficiency (77%) still at about 21 psi, anything above that and youre starting to push hotter air. At that point it looks like youll be pushing arond 450cfms
Old Oct 3, 2005 | 03:04 PM
  #96
urbansi's Avatar
Default Re: (ITSME4G63)
link does not work
Old Oct 3, 2005 | 04:41 PM
  #97
fkneh's Avatar
Default Re: Pushing the 18G (fkneh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkneh &raquo;</TD></TR><TR><TD CLASS="quote">okay I have a mitsu TDO5 small 16G. A guy in my area is selling a 18G with no exhaust housing for really cheap like $100. Should I pick up the 18g and use the 16g exhaust housing?
btw I have a gsr</TD></TR></TABLE>
so my housing idea will work right
Old Oct 3, 2005 | 05:16 PM
  #98
Snoochie Boochies's Avatar
From: behind the dumpster, w./your bitch, w./your bitch
just posting randomly... i built a 2.2l stroker @ a yr ago w./8.0:1 and stock gsr head using the greddy kit out of the box no changes, including boost. we used rc 550 injectors, fabbed a down pipe (using a cnc'd flange v-band clamp, and 3" stainless mandrel bends) greddy e-manage. this setup easily made 290hp/220lb.ft. all this at 8psi. since then we added a profec b, and are waiting for the customer to bring it back to make some better #'s from the 18g
Old Oct 3, 2005 | 09:52 PM
  #99
urbansi's Avatar
Default Re: Pushing the 18G (ma70tt)
well the 2.2 i am sure does the trick
Old Oct 4, 2005 | 01:02 AM
  #100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">well the 2.2 i am sure does the trick </TD></TR></TABLE>
it does without question, but not eberyone can afford that, cant wait to post dyno sheets of this motor at 25-35lbs w./the new turbo. but i will see what it does at 15lbs w./the 18g first.
