Pushing the 18G
Old Sep 28, 2005 | 06:34 AM
  #51
JDMisGOOD's Avatar
Default Re: (93si-hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted4dr &raquo;</TD></TR><TR><TD CLASS="quote">
What is his setup?</TD></TR></TABLE>
Stock B18C1
Sheetmetal Intake manifold
RC 440's
Walbro 255
AEM engine management
DC sports exhaust
Old Sep 28, 2005 | 06:38 AM
  #52
urbansi's Avatar
^dyno sheet?
Old Sep 28, 2005 | 06:39 AM
  #53
b00sted4dr's Avatar
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">
Stock B18C1
RC 440's
Walbro 255
DC sports exhaust</TD></TR></TABLE>
Extremely good numbers for that setup. Im guessing its the intake manifold that restricts on b18c1s. WHat downpipe and cat?
Old Sep 28, 2005 | 06:44 AM
  #54
JDMisGOOD's Avatar
Default Re: (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">^dyno sheet?</TD></TR></TABLE>
I can get a copy of one this weekend.
Stock greddy downpipe
No converter
Old Sep 28, 2005 | 06:45 AM
  #55
1sikhatch's Avatar
Default Re: (b00sted4dr)
is there anyway to get more boost out of the dsm 18g w/internal wastegate?
Old Sep 28, 2005 | 06:46 AM
  #56
JDMisGOOD's Avatar
Default Re: (1sikhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">is there anyway to get more boost out of the dsm 18g w/internal wastegate?</TD></TR></TABLE>
Define "more" boost
Old Sep 28, 2005 | 06:54 AM
  #57
1sikhatch's Avatar
my bad what i meant was i'm using the stock internal wastegate and i wanna run about 15 psi
Old Sep 28, 2005 | 08:20 AM
  #58
99blusi's Avatar
15psi is easy on the internal gate. That's about the end of the line though. I've been pushing 15psi for a while on the internal wastegate, just pulled it recently to port the flapper...now I have a new manifold and a tial that I'm going to try out next spring.
I can't say that porting the wastegate helped at all because I barely got to drive the car this year. I do however know that I can't get the boost over 16psi...but the tial should take care of that.
Old Sep 28, 2005 | 10:19 AM
  #59
BoostR41's Avatar
Default Re: (99blusi)
it isn't the wastegate that restricts boost it is the cast elbow and the crap greddy exhaust housing
Old Sep 28, 2005 | 12:15 PM
  #60
93si-hybrid's Avatar
What other exhaust housings fit the 18G?
Old Sep 28, 2005 | 01:37 PM
  #61
nfn15037's Avatar
Default Re: (BoostR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">it isn't the wastegate that restricts boost it is the cast elbow and the crap greddy exhaust housing</TD></TR></TABLE>
Maybe you are not farmiliar with basic turbocharger function, but the wastegate size has a huge impack on how much the exhaust side of a turbo system can flow. Once your desired boost is reached, the wastegate is open, effectively increasing exhaust surface area. The cast elbow creates a restriction downstream of both the turbine outlet and the wastegate hole. So yes, it is the cast elbow with its 2 inch outlet that severly restricts the Greddy 18G.
Old Sep 28, 2005 | 02:16 PM
  #62
urbansi's Avatar
Default Re: (nfn15037)
NFN^^^ you got pm
Old Sep 28, 2005 | 02:42 PM
  #63
JrCRXHF's Avatar
Default Re: Pushing the 18G (urbansi)
the turbo should be able to do that easily becuase with a EVO3 16g buschur made 400.7 whp
Old Sep 28, 2005 | 04:20 PM
  #64
urbansi's Avatar
Default Re: Pushing the 18G (JrCRXHF)
different turbo, different motor............ pretty much sums that up
Old Sep 28, 2005 | 04:28 PM
  #65
btotherizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe you are not farmiliar with basic turbocharger function, but the wastegate size has a huge impack on how much the exhaust side of a turbo system can flow. Once your desired boost is reached, the wastegate is open, effectively increasing exhaust surface area. The cast elbow creates a restriction downstream of both the turbine outlet and the wastegate hole. So yes, it is the cast elbow with its 2 inch outlet that severly restricts the Greddy 18G.</TD></TR></TABLE>
Is there a direct replacement on the market for the 2'' elbow. I have a 3'' downpipe connected to the elbow now. I also welded a turbosmart 38mm to the mani so now i can run 20psi with no spikes and no creep. After 2 years of the internal gate and it's bullshit this is a nice change.
Old Sep 28, 2005 | 08:39 PM
  #66
BoostR41's Avatar
Default Re: (btotherizzle)
the mitsu housing will bolt up to the turbo, but the flange won't match the nissan T25 on the greddy mani
Old Sep 29, 2005 | 05:35 AM
  #67
blaze the chemi's Avatar
I PM'd you Urban.
Old Sep 29, 2005 | 05:36 AM
  #68
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">Is there a direct replacement on the market for the 2'' elbow. I have a 3'' downpipe connected to the elbow now. I also welded a turbosmart 38mm to the mani so now i can run 20psi with no spikes and no creep. After 2 years of the internal gate and it's bullshit this is a nice change.</TD></TR></TABLE>
Not that I know of. Look back a couple pages in this thread to see what I did (Vband adaptor and custom DP).
Old Sep 29, 2005 | 07:19 AM
  #69
urbansi's Avatar
at some point there was a company out of canada that made a full replacement with like a seperate tube for the wastegate and all that but they were like $450 and no one was buying them(sexy as hell looking too), i know i saw it here on H-T like a while back, if i have some time at school today i will post the link.
Old Sep 29, 2005 | 02:41 PM
  #70
urbansi's Avatar
no luck finding the link, but a bump
Old Sep 29, 2005 | 02:52 PM
  #71
Drag_On's Avatar
Regardless, compression has very little effect on spool time. Compression is not really responsible for exhaust gas volume.</TD></TR></TABLE>
Right but lower compression means less response when OUT of boost on a street car.. So if it responds better before boost sets in and then has quick spool up because of the smaller turbo - it will be a better street car than one with 8.5:1 commpression and the same boost and same lag..
See where I'm going with that? It will spool quick with small turbo and run better OFF boost since its higher compression.
Old Sep 29, 2005 | 09:02 PM
  #72
urbansi's Avatar
Default Re: (Drag_On)
interested in seeing some more dyno's of more built motors with 18G's
Old Sep 29, 2005 | 09:19 PM
  #73
BoostR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">interested in seeing some more dyno's of more built motors with 18G's </TD></TR></TABLE>
here is my dyno sheet(sorry it is so big) you can see boost was jumping around up top. I finally turned the boost controller to all the way sharp on response today and it just slighty jumps now though I have no dyno sheet to prove it with:
Old Sep 29, 2005 | 11:19 PM
  #74
avex's Avatar
my god would i kill to get that kind of spool from my 18g. mine takes forever to ******* spool up for some reason.
Old Sep 29, 2005 | 11:42 PM
  #75
urbansi's Avatar
Default Re: (avex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avex &raquo;</TD></TR><TR><TD CLASS="quote">my god would i kill to get that kind of spool from my 18g. mine takes forever to ******* spool up for some reason. </TD></TR></TABLE>
when do you see full boost, i see 5psi by like 4k, then hit 9psi at like just short of 5500
