pros and cons of running WG open or closed
Old Apr 17, 2004 | 08:03 PM
quik sol's Avatar
Default pros and cons of running WG open or closed
I was just wondering where the good and bad of running both open or closed wg?
Reason why I ask is the way my turbo sits its going to be a pain to make a tube from the WG to the downpipe so I am just wondering if I can run it open safely
Old Apr 17, 2004 | 08:07 PM
J337_UNIT's Avatar
Default Re: pros and cons of running WG open or closed (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering where the good and bad of running both open or closed wg?
Reason why I ask is the way my turbo sits its going to be a pain to make a tube from the WG to the downpipe so I am just wondering if I can run it open safely</TD></TR></TABLE>
your referring to a open/closed LOOP set up for your wastegate. put it this way
Closed loop = more quiet, little less power, routes back to downpipe
Open loop = loud when your wastegate opens up, nice power, dumps exhaust in atmosphere. depending where this dumps the exhaust, some people complain of a dirty hood on the underside/ dirty engine bay.
Old Apr 17, 2004 | 08:10 PM
SleepyEG's Avatar
To add an additional note, the external dumping setup will not make more power because the exhaust is going under the car...
With the wastegate'd exhaust no longer going back into the regular exhaust stream, the regular stuff that passed through the turbine effectively has a "larger" area to flow through.
Old Apr 17, 2004 | 08:11 PM
quik sol's Avatar
not worried about it the cleanliness as much...I will clean it weekly if I have to...is there anything you have to put over it so stuff doesnt get in there?
Old Apr 17, 2004 | 08:14 PM
J337_UNIT's Avatar
Default Re: (quik sol)
you will be FINE if you make the dump tube at least down to the oil pan..
Old Apr 17, 2004 | 08:18 PM
B18bEK's Avatar
Default Re: (J337_UNIT)
like 99% of people run an open loop dump tube ..
Old Apr 17, 2004 | 08:20 PM
quik sol's Avatar
Alright so just make a little pipe shooting down in the oil pan area?
Old Apr 17, 2004 | 08:49 PM
B18bEK's Avatar
ya. mine is a little short but it works fine - kinda gets my air filter dirty.
Old Apr 17, 2004 | 09:41 PM
accordfreak's Avatar
Default Re: (B18bEK)
CLOSED dump all the way!
Old Apr 17, 2004 | 09:51 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">ya. mine is a little short but it works fine - kinda gets my air filter dirty.
That looks exactly like mine except mine exits just below the oil pan.
Old Apr 17, 2004 | 10:53 PM
nevin's Avatar
how much power difference is there with the two setups?
Old Apr 17, 2004 | 11:00 PM
Paul W's Avatar
Default Re: (nevin)
open loop can be wayyy loud
Old Apr 17, 2004 | 11:49 PM
11psiTurboSI's Avatar
Default Re: (VRBtchcar)
I extended the drag dump tube down to the groundand sounds quieter compared to before and now it doesnt shot exhaust gases down on my i/c makin the temps hotter
Old Apr 18, 2004 | 12:03 AM
MikeMAN's Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">how much power difference is there with the two setups?</TD></TR></TABLE>
lots, ur talking (depending on ur setup) 20-70 hp
mike
MikeMAN's Avatar
Default Re: (MikeMAN)
plus, open dump just says "dont mess with this car...its angry"
mike
Old Apr 18, 2004 | 12:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
doesn't it depends where you route it? i thought the corky bell's book said you shouldn't have any loss in power if it's 18" down from the turbo. ? just confirming.
i'd rather have a silent killer
Old Apr 18, 2004 | 12:09 AM
calib17a's Avatar
Just extend it with a worm gear clamp on a radiator hose onto you dumptube and route it below the block.
Old Apr 18, 2004 | 12:34 AM
HXMan's Avatar
Default Re: (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">? i thought the corky bell's book said you shouldn't have any loss in power if it's 18" down from the turbo. ? </TD></TR></TABLE>
He says to route it AT LEAST 18" from the turbo. The ideal exhaust he says would have a seperate exhaust for the turbo and wastegate.
Old Apr 18, 2004 | 01:45 AM
NCchris's Avatar
Default Re: (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">
He says to route it AT LEAST 18" from the turbo. The ideal exhaust he says would have a seperate exhaust for the turbo and wastegate.</TD></TR></TABLE>
Yeah, he also says that the best exhaust is no exhaust, right under that picture of the twin turboed porsche with the twin open dumptubes and the twin open exhaust.
Not pratical on a street car though.
chris
Old Apr 18, 2004 | 07:08 AM
JDMCRX's Avatar
Default Re: (NCchris)
I have a open dump love it mines plumbed under the car towards the drivers wheel
love it people are like what the **** that scarry
4dek
Mar 8, 2008 10:39 PM
EK FLY
Jul 8, 2006 06:26 AM
Ryceboi318
Jan 19, 2005 06:37 PM
Scott - 93HB Si
May 16, 2003 04:58 AM
stealthteg
Apr 17, 2002 09:35 AM
