BOV problem (turboXS rfl)
Old Apr 13, 2004 | 05:11 PM
pip9's Avatar
Default BOV problem (turboXS rfl)
I had a hks ssv before and never noticed this problem. I have the turboXS rfl now. If i get on my car and it boosts up to full boost and even alittle lower the bov goes off with no problems (loud wooossshhh), but if im going along at part throttle and hit slight boost and let off i'll get compressor surge for a sec or so then a high pitched sound from the bov. Is this normal? I have the bov on like it came in the package. As loose as it can get (no washers added). Anyone have this problem? How do i fix it?
Old Apr 13, 2004 | 05:13 PM
slim9300's Avatar
Default Re: BOV problem (pip9)
How many lbs. of boost are you running? But just for the record, I am not a big fan of Turbo XS BOV's, they seem to have this problem and many others alot.
Old Apr 13, 2004 | 05:16 PM
pip9's Avatar
I was running .5bar when i noticed it, but i'm running .7bar now and i still get it
Old Apr 13, 2004 | 05:20 PM
slim9300's Avatar
Default Re: (pip9)
Wierd, it's not like you are running that low of boost. Just blame it on the fact that it's a Turbo XS BOV, everyone will just smile and nod.
Old Apr 13, 2004 | 05:22 PM
pip9's Avatar
Default Re: (slim9300)
Would adding the washers help at all? I guess i could just hit full boost then let off every time
Old Apr 13, 2004 | 05:27 PM
Hoosier Daddy's Avatar
Default Re: (pip9)
Check your vacuum source. Is the signal strong enough? This happened with my Greddy Type S. I would get compressor surge/very high pitched sound all the time. I rerouted the vacuum lines and with a stronger signal it worked great. Just a thought.
Old Apr 13, 2004 | 05:29 PM
99B16Si's Avatar
try a larger vacuum line with some zip ties, i guarantee it solves the problem
Old Apr 13, 2004 | 05:49 PM
pip9's Avatar
Default Re: (99B16Si)
All my vacuum lines are zip tied on. It's the larger silicon type thats on my bov. I got some regular stock looking vacuum lines from my work. Maybe i'll try that and make the line as short as possible. thanks.
Old Apr 13, 2004 | 05:56 PM
1700anddroping's Avatar
hey there is nothing wrong with the rfl bov's.it is your vacum source.i had mine connected at the throttle body and it didn't do to good,so i ran it straight to the back of the manifold and it works great.
Old Apr 13, 2004 | 06:44 PM
boosted_dc2's Avatar
Default Re: (1700anddroping)
where is it connected??? and no dont add washers that will make it worse.
Landon
Old Apr 13, 2004 | 06:48 PM
Default Re: (boosted_dc2)
i connected mine to the back of the manifold"dedicated line".
i never mention washers so i don't know where you got that.i have 2 rfl's going on my personal set up"h22 stroked and turboed". 93 hatch
Old Apr 14, 2004 | 02:45 PM
pip9's Avatar
I think i fixed it today. I took off all the silicon vacuum lines and replaced them with the stock looking rubber ones and made them all a short as possible and zip tied them up. I just hear a high pitch noise at part throttle and letting off. No more compressor surge. thanks for ur help.
Old Apr 18, 2004 | 06:39 AM
pip9's Avatar
It came back or maybe it really didn't go away. I dont seem to notice it til my car warms up now. Its getting really annoying. Is there any other way i can get rid of this compressor surge w/o buying a new bov?
Old Apr 18, 2004 | 07:34 AM
Mad Cow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 &raquo;</TD></TR><TR><TD CLASS="quote">Wierd, it's not like you are running that low of boost. Just blame it on the fact that it's a Turbo XS BOV, everyone will just smile and nod. </TD></TR></TABLE>
Um, no.
Every person that's posted about having this problem (including myself) has fixed it by moving the vacuum line to a better vacuum source, and/or getting a bigger line. You may want to think of investing in a vacuum manifold, mcmaster has them for dirt cheap if you want to save $. Good luck.
Dave.HR
Oct 29, 2010 05:32 AM
CRXdan
Dec 11, 2004 10:38 PM
oemDC2
Feb 26, 2004 08:03 PM
boosted6thgen
Feb 4, 2003 11:53 AM
