profec a vs b which is better
Old May 14, 2010 | 05:06 AM
buffgsr's Avatar
Default profec a vs b which is better
hey just bought a profec a for 75 bucks looks new..the question is which is better and why??? can you do low boost and high boost like the profec b with the A??? any help would be great thanks
Old May 14, 2010 | 07:05 AM
TheShodan's Avatar
Moderator
Default Re: profec a vs b which is better
Ah yes, the Old School Profec A. It was a nice boost controller but complicated for the times compared to the Profec B Spec S or Spec II. Honestly, as much as I like the Spec B II because of its boost "gain" feature to help with response, Boost limiter percentage option, and the digital readout, the Spec S is simple, easy to learn, only uses a couple of *****, and no "percentage" numbers to worry about. Those used to retail for $500 back in 1998-2002, so $75 isn't horrible.
The Profec A has a "fuzzy logic" feature that acts as a boost spike preventer when it comes to setting the boost control for the car. It's a bit more complicated than it should be, but it is very learnable. There's no need to necessarily sell it, but the Spec B in B or S is a better option if possible.
Here's the instruction manual
http://www.greddy.com/img/PHP/products/pdf/688.pdf
Here's the write up in better written english
http://www.supramania.com/forums/sho...stall-write-up
Good luck.. enjoy
boosted_ejcivic
Mar 28, 2007 03:11 AM
B16Civic93
Feb 20, 2005 06:28 PM
FlatTire
Sep 8, 2004 09:39 PM
BodyKits NW
Aug 29, 2003 05:55 PM
duRritztiNy
Mar 14, 2003 02:31 PM
