PROBLEM NEED HELP
Old Oct 30, 2007 | 03:21 PM
simplsi's Avatar
Default PROBLEM NEED HELP
i bought myself a 57 trim ebay turbo and installed it and also i fucked up by hooking up a oil catch can from the valve cover to the can then to the pcv intake manifold. when i was driving it around it started smoking bad. i went home checked the spark plugs and it was oily and my valve cover seals blew. i replace the valve cover seal and took da gay catch can off which i think detonated the motor, and i got my turbo rebuilt with garrett internals. then finally i put everything back in today and it still smokes white/blue at idle. what can possible be wrong? possibly some other seals on the head?
Old Oct 30, 2007 | 03:33 PM
Peter Brady onlyonweekndz's Avatar
Default Re: PROBLEM NEED HELP (simplsi)
you should have put a breather filter on the valve cover..do a compression check and put up some #'s..worst case is its your piston ring lands..
Old Oct 30, 2007 | 03:42 PM
jfruauff's Avatar
Did we boost it a bunch untuned. I say its time for some rebuilding
Old Oct 30, 2007 | 04:08 PM
simplsi's Avatar
i just got my turbo bak yesterday from rebuild and put everything bak in today and it still smokes alot
jared99
Jul 19, 2006 08:40 AM
InfamousDC2FI
May 31, 2006 09:41 AM
1slowdc2
Apr 24, 2006 08:23 AM
boostdB16a
Aug 8, 2003 08:28 AM
not so civic
Apr 7, 2002 02:20 PM
