Precision injector install ?
Old Jun 13, 2007 | 08:30 AM
sohcvtec91hatch's Avatar
Default Precision injector install ?
I just got my turbo kit in from Autoworks and it came with 440cc precision injectors. They didn't come with the bushing for the IM, just the o-rings on the injectors. When I went to install them they wouldn't sit in the stock bushing all of the way. Do I just lube them up and put the fuel rail back on and tighten it down? Or do I need to shave some off of the inside of the bushing?
Old Jun 13, 2007 | 08:32 AM
numbnuts22715's Avatar
for my rc's i shaved some off... I would assume that you have to do the same for the precisions.
Looking at the pictures, it definitely looks like you need to trim some down...
Try a dremel.
Old Jun 13, 2007 | 08:40 AM
PrecisionH23a's Avatar
Default Re: Precision injector install ? (sohcvtec91hatch)
Dremel the o-rings so the injector fits snug inside of it.
Old Jun 13, 2007 | 09:51 AM
mitsuman's Avatar
Default Re: Precision injector install ? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Dremel the o-rings so the injector fits snug inside of it.</TD></TR></TABLE>
X2
Old Jun 13, 2007 | 11:08 AM
Default Re: Precision injector install ? (mitsuman)
I just put the Fuel rail on and tightened it down. Fit perfect IMO I think that is the way to go.
Old Jun 13, 2007 | 11:13 AM
Archidictus's Avatar
Unceasing Measure
x3. Avoid forcing things. Can you tighten the rail until it squishes the incorrectly-sized o-rings in? Probably. Should you? Probably not. Premature breaking and/or shifting in front of the nozzles can occur, and nobody wants that to happen at 14psi
Old Jun 13, 2007 | 12:58 PM
HamiltonRex's Avatar
Default Re: Precision injector install ? (Archidictus)
my 780's fit fine, i just used a VERY small amount of vaseline put it on with a brush, and they fit nicely.
Old Jun 13, 2007 | 04:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
x3. Avoid forcing things. Can you tighten the rail until it squishes the incorrectly-sized o-rings in? Probably. Should you? Probably not. Premature breaking and/or shifting in front of the nozzles can occur, and nobody wants that to happen at 14psi </TD></TR></TABLE>
They didn't exactly snap into place, but they went in with little effort. I was just expecting them to go in like the stockers. So I got them in and went to connect the plugs and they wouldn't go in. After searching for the reason I narrowed it down to the little nipple, inside the center section, by the metal prongs. You can see what I'm talking about in the pic of the 2 injectors in the manifold in my first post.
Here are some more pics of them installed and with the injector next to the plug.
Old Jun 13, 2007 | 05:42 PM
Problem solved! *edit* You can tell on the one in the top right corner better!
Old Jun 13, 2007 | 05:51 PM
B18EG6's Avatar
I was told with my RCs not to shave anything off the o-rings the instructions also said not to
https://honda-tech.com/zerothread?id=1923862
Old Jun 13, 2007 | 07:39 PM
Default Re: Precision injector install ? (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">I was told with my RCs not to shave anything off the o-rings the instructions also said not to
https://honda-tech.com/zerothread?id=1923862</TD></TR></TABLE>
I'm not going to touch the Bushings. I think that they were designed that way.
hoo my gosh
Mar 3, 2008 07:10 PM
S2000Forsale
Honda S2000
Sep 28, 2007 11:26 AM
10seceg
Feb 23, 2004 06:22 PM
sneakypete
Jan 31, 2004 10:39 AM
JMinSi2000
May 7, 2002 07:31 PM
