RC 550 injector install questions
Old Jan 31, 2004 | 01:33 AM
sneakypete's Avatar
Default RC 550 injector install questions
I'm going to be helping my buddy install his rc 550's tomorrow into LS engine. From the research that I've done the rc's come with all the injector seals. Also I remember when I installed my precesion 440 injectors I had to dremel part of injector for the clip would fit inside the injector. Will I have to do this for the rc's? He has obd 1 injector clips. Any other helpful advise would be appreciated. Thanks
Old Jan 31, 2004 | 08:26 AM
Rain_man's Avatar
New User
Default Re: RC 550 injector install questions (sneakypete)
When I installed my satured RC 550's on my LS, I didn't need to dremel anything. I have OBD 1 clips too.
Old Jan 31, 2004 | 08:56 AM
sneakypete's Avatar
Default Re: RC 550 injector install questions (Rain_man)
Good, how about the injector seals? Did you re-use the stock one that sits in the intake manifold or did you use the one that came with the rc injectors? You didn't have to go to the store and buy the injector seal kit did you? Thanks rainman.
Old Jan 31, 2004 | 09:21 AM
FOrSfEd's Avatar
I would get an injector seal kit. I reused mine and for a while they worked fine but now I'm running into a small fuel leak problem.
Old Jan 31, 2004 | 10:39 AM
5thgencivic's Avatar
Default Re: RC 550 injector install questions (FOrSfEd)
My RC's came with new bottom seals, top orings and cushions.
The only thing I noticed when putting mine on, were we used 3 small washers under the fuel rail(on the 3 studs) to washer it up a bit. Otherwise the "cushions" get really smashed down. Also, the injector harness/clips sit closer to the rail so it's a little bit of a tight fit.
donut.
48
Mar 21, 2008 06:26 AM
S2000Forsale
Honda S2000
Sep 28, 2007 11:26 AM
dalecrx
Apr 12, 2007 07:50 AM
chihuahuamanx
Apr 5, 2005 10:49 AM
Mucackus
Apr 23, 2002 06:33 AM
