Honda S2000 Honda S2000
Rc 1000cc install problems
Old Sep 27, 2007 | 07:24 PM
S2000Forsale's Avatar
Default Rc 1000cc install problems
I used to have the rc 750cc and the install and fitting was great. So my first question is, the RC injectors universal?
how is the bottom ring is supposed to go?
If this O-ring goes like the injector is the right. the top bolts will not clear.
If the O-ring is suppose to go like the injector in the left. the injector will not go all away in.
whats wrong with this?
Old Sep 28, 2007 | 08:51 AM
m R g S r's Avatar
Default Re: Rc 1000cc install problems (S2000Forsale)
Just bore the injector O ring out....it's not that hard to figure out common....you have a turbo (I'm guessing with injectors that large) s2000...and you don't know what to do when the diameter of the injector is larger than the inner diamater of the seal?
Old Sep 28, 2007 | 11:26 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Rc 1000cc install problems (m R g S r)
it works both ways.. all depend on teh IM you use sometimes.... just seat the injector and tighten it down slowly in a pattern to tighten it evenly... and you should seal.. pressure check it before firing it off
Pompiuses
May 12, 2012 11:14 AM
Toanz
Apr 28, 2008 03:22 PM
hayabusa160
Aug 10, 2004 09:42 PM
95gsr
Mar 3, 2004 04:50 AM
sneakypete
Jan 31, 2004 10:39 AM
