post pics of your welds !!!
Old Feb 6, 2003 | 05:22 PM
  #76
paulzy's Avatar
Default Re: post pics of your welds !!! (project dc2)
yeap...24guage or something like that...it's very, very thin. You just have to play with the heat and wire settings so you won't burn holes while welding, plus get ebough heat to penetrate the metal
[Modified by 1320development, 1:36 PM 2/6/2003]
what are your techniques and settings for welding that **** ??
Does that mean you like my welds? I'm so happy...hahha...j/k
i usually set wire feed at about 10-15 and voltage anywhere from 2-4.
Just go slowly and move the gun back and forth, so that it moves the molten metal around...teh zig zag or half moon works also
Old Feb 6, 2003 | 05:51 PM
  #77
project dc2's Avatar
Default Re: post pics of your welds !!! (1320development)
oh .. don't flatter yourself. they're OK... J/K... im just suprised u could actualy weld such godamn thin metals. maybe i just need to create no gappage at all with my charge pipes 18 gauge. cuz i always have a problem with melting it tru, i used the #2 voltage setting and about 25 wire feed, i kept burnin holes so i just did voltage 1 setting at 15 wire speed and it was ok, but i wasnt used to the speed ... ill be finsishin my manifold tomarorw, ill see if i can get some pics.
Old Feb 6, 2003 | 07:40 PM
  #78
racerxadam's Avatar
or I wish i had a tig welder, if my shop was a fab shop rather than a body shop I probably would.
Old Feb 6, 2003 | 07:53 PM
  #79
BenMara's Avatar
Default Re: post pics of your welds !!! (racerxadam)
Who cares what the welds look like as long it holds and you penetrate it
Old Feb 6, 2003 | 08:21 PM
  #80
Smashback's Avatar
Default Re: post pics of your welds !!! (BenMara)
We are very superficial here..I sometimes lose it when I make an ugly weld. I'll spend an hour grinding it down and posibly covering it with a better weld
Old Feb 6, 2003 | 08:23 PM
  #81
tony1's Avatar
Default Re: post pics of your welds !!! (Hatchblack)
A bad weld is embarrasing, I would never let one leave my shop with my name on it! A good weld takes time and skill, something everyone should want to show off.
Old Feb 6, 2003 | 08:27 PM
  #82
Flamenco-T's Avatar
Default Re: post pics of your welds !!! (LsTurbo91)
that is horrendous hehe j/k. The bead is all over the place, I'll have to show mine later tonight
How thick is the metal? What wire size are you using?
do I need to post my oil pan ? LMAOL
well, it's still better than my ghetto *** core flux weld on my DP
hehehehe
stan
Old Feb 6, 2003 | 08:32 PM
  #83
paulzy's Avatar
Default Re: post pics of your welds !!! (Flamenco-T)
very true, the way a weld looks reflects upon the welder's image. BUt it is true though....as long as teh weld penetrates, then you're straight
Old Feb 6, 2003 | 08:33 PM
  #84
LsTurbo91's Avatar
hehehehe
stan
haha, yea that was when i had the ghey *** $100 welder, this new one i have is night and day difference. No dual heat settings like the old one, lol (umm HI or LO) hahah that welder is so ghey.
Old Feb 6, 2003 | 08:48 PM
  #85
racerxadam's Avatar
One thing that greatly improved my welding was an auto tinting helmet. Only gets dark when it needs to be otherwise you can see without flipping up the helmet.
Old Feb 6, 2003 | 08:57 PM
  #86
LsTurbo91's Avatar
yes defenitely on the auto-darkening helmet. The problems im having is I can't continously weld the bead, I have to stop, rotate the damn pipe start again so its not smooth all the way through
here's a ic pipe i did awhile back. You notice the start and stop action going on, bead starts/stops/starts. Sorry for the blurry pics
Old Feb 6, 2003 | 09:03 PM
  #87
Full-Race Javier's Avatar
i tried an auto tinting helmet once.....every time i would start welding, i would motion my head down.....trying to rotate the helmet down, even though it was already down! a regular helmet is VERY habit forming sometimes i do the same thing when i solder
Old Feb 6, 2003 | 09:10 PM
  #88
Default Re: post pics of your welds !!! (javierb14)
how do u work with having to start n stop ?? any tricks to that ? i notice that gets annoyin, havin to rotate **** and it ***** the bead up cuz you gotta start n stop
Old Feb 6, 2003 | 10:25 PM
  #89
eventually u have to stop, unless u have one of those machines that rotates the parts(cant remember the name). it takes a little practice to get ur wrist to "rotate" and continue the bead. just keep trying
wait till jon post pics of his work tomorrow!
Old Feb 7, 2003 | 03:02 AM
  #90
racerxadam's Avatar
I got a question for you guys. How many of you have gotten "sunburn" from welding? I went to the shop last night to run those beads that i posted above and this morning my hand is totally red and sunburnt. Must be the way I use my left hand to steady the right when I'm using the MIG. This is the second time in like 3 weeks that I have done this.
[Modified by racerxadam, 7:02 AM 2/7/2003]
Old Feb 7, 2003 | 05:55 AM
  #91
you're suppose to wear gloves because the welding emmits a lot of heat and UV rays.
Old Feb 7, 2003 | 10:10 PM
  #92
i've got a "tan" from welding a few times its usually when im welding for extended periods of time. FWIW some welders put sunblock on before they weld.
Old Feb 7, 2003 | 11:21 PM
  #93
TheShocker's Avatar
I got a really bad "sun" burn from welding once. Man that hurt...
Old Feb 8, 2003 | 01:28 AM
  #94
InfamousRS's Avatar
Default Re: post pics of your welds !!! (TheShocker)
Dang...Im really starting to miss welding. I welded almost every day in high school in a class call Advanced Manufacturing Technology. I wish I had some of my sample welds to show you guys...didn't even think to keep them after I was done with school.
A majority of the welding I did was MIG. I got extremely good at it. It sucks though cause about a year later I had to make my self a test pipe, just in that year my welds went WAY down in quality. there weren't very flat or straight.
I really want to get a nice MIG setup, but don't want to spend a ton of money. What would be best buy for $500 or under?
Old Feb 8, 2003 | 06:45 AM
  #95
Phoenix GSR's Avatar
Default Re: post pics of your welds !!! (InfamousRS)
InfamousRS - check here for the same question
https://honda-tech.com/zerothread?id=409908
[Modified by Phoenix GSR, 9:45 AM 2/8/2003]
Old Feb 8, 2003 | 07:42 AM
  #96
meanteg's Avatar
New User
Default Re: post pics of your welds !!! (Phoenix GSR)
Old Feb 8, 2003 | 09:02 AM
  #97
c1hatch's Avatar
Looking good,
Im going to take my I-CAR weld certification tests come this april.
I used .030...this is like some 24 gauge sheetmetal I had laying around
paul, you probably get better puddles if you use .023 wire for that gauge metal you are welding. .030 would be good for around 18/20 gauge sheet metal
[Modified by c1hatch, 10:22 AM 2/8/2003]
Old Feb 8, 2003 | 10:06 AM
  #98
dustin's Avatar
A little above your range, but it includes shipping:
http://www.cyberweld.com/millermatic135.html
Old Feb 8, 2003 | 10:58 AM
  #99
InfamousRS's Avatar
Default Re: post pics of your welds !!! (dustin)
I was looking at that one last night actually. I also looked at the Hobart 135... out of the 2, which would you suggest?
Old Feb 8, 2003 | 11:01 AM
  #100
dustin's Avatar
It's basically the same welder. Miller and Hobart are the same company now.
However, the Hobart only has a 4 position voltage selector and the Miller has "infinite" adjustment. The 4 position limitation is going to be a pain if it just doesn't seem to work well with the thickness of metal you are welding.
