piston to wall cleareance?
Old Feb 17, 2010 | 12:23 PM
turboman2.2's Avatar
Default piston to wall cleareance?
Alright i got my block out of my car and about to call the machine shop to get a cost estimate to bore out the block .5 over. My pistons are 81.5mm wiseco. I have goals for 450-500 hp. what would be the best clearence for this? Also how much do you think they would charge? oh and its a b18b1 obd1. and what do you recoment for the piston rings/???
Old Feb 17, 2010 | 01:55 PM
E85B18's Avatar
Default Re: piston to wall cleareance?
Are they high or low silicone? Go with what wiseco recommends. I have Arias and I ran mine at .0040 Above 500hp you could go with .0045 but again this is with Arias. Check my thread for a little more info and a video of my clearance.
https://honda-tech.com/forums/forced-induction-16/arias-piston-wall-clearance-2706644/
Old Feb 17, 2010 | 02:13 PM
bzyq2001's Avatar
i have 84mm cp in bensons block, my P2W is 0.0060 i'm shooting in 600hp range, do i need biger pistons, or it will be ok with that P2W with 0.0060 ?
Old Feb 17, 2010 | 02:22 PM
E85B18's Avatar
What does CP recommend? .0060 is a lot of clearance even with 600hp. The only time Ive heard of people running close to that is with 800+ hp. Wait for others to chime in but I bet they will tell you to go with 84.5 and have your block remachined to .0045 or so
Old Feb 17, 2010 | 02:29 PM
90blackcrx's Avatar
Talk to a reputable builder and see if he has any input or suggestions.
Old Feb 17, 2010 | 03:36 PM
BiggieBert's Avatar
Loved
Community Favorite
If you are broken in properly and on proper tune .006 should not be a problem. You might have tiny bit of piston slap in low rpms but it will be minimal.
I ran .008 on my initial turbo build and I tried to break it in on a base-map and cylinder 4 didn't seal properly.
Old Feb 17, 2010 | 04:03 PM
TimKennard's Avatar
if i remember correctly, the wiseco instructions said .0025 and i went with .0035. and this is on a 81.5mm b16.
Old Feb 17, 2010 | 04:49 PM
SovXietday's Avatar
A little loose is a good thing for boosted setups. If I was building your motor I'd be .004-.0045
Old Feb 17, 2010 | 04:52 PM
ashb82's Avatar
X2
Old Feb 17, 2010 | 05:31 PM
i think i might go .0035 but still not sureee
Old Feb 17, 2010 | 05:45 PM
crxcel's Avatar
I went .004 with my weisco's. better a little loose than taking the cylindrrs out
Old Feb 17, 2010 | 07:07 PM
jdm602's Avatar
sometimes its good to run a little looser compared to what they call for. especially if you plan for more power down the road. i say .004 to .0045. shoot, a buddy of mine is running .006 on a stock sleeve motor. but thats around 600 wheel.
Old Feb 17, 2010 | 08:08 PM
.004 would probably be the lucky nnumber then.... how much hp do u think this would work with?
Ryhaz
10
Jan 14, 2014 07:57 AM
kyden
Jun 12, 2009 08:16 AM
got wide
Sep 4, 2007 03:55 PM
Robban26
15
Jan 24, 2004 01:31 AM
crx1856
Nov 3, 2003 05:10 AM
