piston/wall clearance rings r visable?
Old Sep 4, 2007 | 09:48 AM
got wide's Avatar
Default piston/wall clearance rings r visable?
ok i gotta be quick but i just got my short block sleeve/build back from erl performance and there is a LOT of clearance between the piston and cylender wall enough to see the rings is this normal for a low comp build.
Old Sep 4, 2007 | 09:51 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: piston/wall clearance rings r visable? (got wide)
measure the wall clearance, and compare it to acceptable tolerances
Old Sep 4, 2007 | 10:29 AM
:Josh:'s Avatar
Just remember that the piston is always smaller at the top by the rings (usually around .030"-.040") than down by the skirt.
Old Sep 4, 2007 | 12:12 PM
got wide's Avatar
Default Re: piston/wall clearance rings r visable? (:Josh:)
yeah the skirt looksa lot closer ive just never seen a specially built block and thought it looked odd that i could see the rings.
Old Sep 4, 2007 | 03:55 PM
got wide's Avatar
ok i just got home and read the clearance sheet and it says the piston skirt clearance is .0045 but does not give a spec for the top of the piston but does this sound about right for the skirts, oh yeah the block is a b18c1 built with 84 mm darton MID sleeves and top and side coated JE 84 mm pistons w/ 8.0:1 cr
i just remember pulling the block apart before i sent it out and i know the clearances were no where near as big as they are now, i just want to make sure this is normal and the pistons arnt gonna rattle around or have extreme blow by before i put the head on.
oh and what do i need to measure the wall clearance with the pistons in,or can i?
GT500FTW
Jan 5, 2013 02:35 PM
dgie
Jul 9, 2008 09:01 PM
b18sihatch
Nov 16, 2006 03:38 PM
KingOfQB
10
Mar 4, 2006 07:30 AM
MrCrx
Jun 17, 2003 09:08 AM
