new to boost d15b7
Old Feb 17, 2010 | 08:13 PM
fg10's Avatar
Default new to boost d15b7
I was wonderin if i just get a small turbo kit for it could i just install it an get a tune around 5 psi and be done and ready, or what else would i need??? i tried searching but just started a topic.
any help or input please
Old Feb 17, 2010 | 08:32 PM
lyncoors's Avatar
Default Re: new to boost d15b7
7psi is safe. injectors and a tune you should be set
Old Feb 17, 2010 | 08:43 PM
dapek's Avatar
PSI is relevant to what turbo is being used. So saying 7 psi is good is just plain stupid. OP, this exact question has been asked/answered a million times over. Go through the FAQ and search homey.
Old Feb 17, 2010 | 08:44 PM
fg10's Avatar
alright thanks man, 440 injectors sufficent? and i heard i could run stop fuel pump also. what i really want is to go turbo but not have to change many stock parts thats why i mensioned 5psi or so lmk
Old Feb 17, 2010 | 09:08 PM
Schister66's Avatar
Man U FTW
Ugh....
For a stock internal D series, the safe range is generally in the 200-220whp range; however, those are generally D16Z6/Y8 rather than the B7. For your goals, plan it in terms or power created rather than boost. PSI is an irrelevant measure which varies depending on the turbo used. As for your injector choice, a set of 440s would certainly be enough. Tuning can be done on Crome if your budget is tight. If you have more to spend, there are other options available as well.
Read the FAQ...many of your questions will be answered there
Old Feb 17, 2010 | 09:12 PM
lyncoors's Avatar
just saying all bolt on turbo kits says it runs 7psi safely, so 7psi is safe lol
Old Feb 17, 2010 | 09:23 PM
fg10's Avatar
Alright thanks for the help ill check the FAQ;s and have much more to learn
Old Feb 17, 2010 | 09:25 PM
Schister66's Avatar
Man U FTW
It happens...we all have to start somewhere.
RELLiK509
Sep 26, 2011 07:12 PM
Headlessmunky
May 8, 2008 08:37 PM
civintegra
Jul 17, 2007 12:31 PM
burks
Apr 30, 2007 02:13 PM
prabtej_si
Jan 25, 2005 09:02 PM
