Piston to wall clearance on cp's?
i am sending my ls block off to get a bore + hone for my cp pistons. what ptw clearance should i shoot for? ls block 400-500whp. its going to be my daily driver during the summer. i see on the sheet that came with the pistons it says .0035. should i go for a little bigger, like .004 or .0045?
Unless they have changed, I was under the impression that if you buy an 81mm piston you should bore to 81mm exact. The tolerance is built into the piston.
Ryhaz
10
Jan 14, 2014 07:57 AM
