pics of turbo install..need some criticism
i just finished doing my first install. what i got is posted on the bottom. please try to let me know what else i gotta do other than clean up the injector wires. im also smelling fuel everytime i boost.....where else can i check for a fuel leak besides the rails and injectors?
[Modified by ceemarun, 11:41 PM 7/21/2002]
[Modified by ceemarun, 2:07 AM 7/22/2002]
Re: pics of turbo install..need some criticism (ceemarun)
check the fuel filter? did you change it recently or mess with it during the install? be careful with fuel leaks....sometimes there can be a slight leak that you wont see it at idle, but when you boost, it will leak and by the time you get out and check, it evaporated.
those are some big pix. looks good! btw- are you having any kind of heat problems?? is your stock temp guage on normal temp?
it must suck to drive in pot hole SF....
oh and you should upload your pix to http://www.digitalpose.com cuz all you see are X's for geocities..
pcguy760
08-10-2008 02:41 PM
