GReddy Relic running (4)additional RC 310' on the d16 Sohc Turbo?
I am getting the GReddy Relic from a friend, it runs 4- 310RC injectors. The motor uses the stock injectors, the 310's only come on when boost is sensed.
The 4 additional injectors are mounted on the bottom side of the intake manifold.
Would this set-up work better then the V_AFC hack?
Afc still tends to run rich, so this is why i would like to get some info on anyone that has used the GReddy Relic.
Peter
Peter
Re: GReddy Relic running (4)additional RC 310' on the d16 Sohc Turbo? (PJager)
it would work if you tune it correctly. You wont need that much fuel for low boost application.
With rods and pistons i want to run 10lbs or more, and the pistons will be a lower compression then the original ones..
I will also be using the MSD ignition system, and tune it on a dyno so it will be done right.
Short cuts cost in the end, and I do not like to waste money.
djvtoner
07-28-2005 10:45 AM
CivicRaping
04-28-2005 11:22 AM
