Optimized configuration for Hondata
Old Dec 25, 2001 | 11:05 PM
  #26
threatcon13's Avatar
New User
Default Re: Optimized configuration for Hondata (Xerxes)
anyone have a URL where i can find an essex? fpr 1:1...plannin on hondata 2b w/ holley intank,440 injectors within 2 weeks.( when i get back home from break)
Old Dec 25, 2001 | 11:28 PM
  #27
LsTurbo91's Avatar
With 440cc injectors and about 50psi of static pressure (60psi at 10psi of boost), I was hitting around 85% duty cycle at 8000rpm at the dyno.
I've got a '99 Civic Si w/ Hondata & a Greddy turbo kit.
I would recommend 550cc injectors for your setup, in order to keep the pressures & duty cycles nice and low.
-Xerxes
Glad im not the only one maxing 440's, Im way past 80% duty cycle, Im hitting around 15-16ms at 6000rpms. I've tested my stock FPR it does rise under boost so I know thats not the problem and Fuel pressure is good about 65lbs rail pressure at 9lbs of boost. Can you tell me your pulse width when you hit 85% on your datalogs ?
ELSpool
May 26, 2004 12:11 PM
TurboJesse
Aug 27, 2003 07:27 AM
hatchback
May 20, 2003 09:00 PM
jeffro_rex
Aug 9, 2002 11:57 AM
HXMan
Jun 2, 2002 10:23 PM
