Ongoing Wastegate boost issues. Please see inside.
Old Aug 6, 2004 | 05:00 AM
  #26
CRX T-Si's Avatar
Default Re: (SiRiUsWeRkS)
Did you try to disconnect your Boost controller to see if that's the problem??
More boost is usually caused by a bad solinoid if you have a boost controller.
Disconnect that **** and try to see if the boost is regulated, since you said that you have a .7 bar spring then your boost should not go higher then 8psi I believe.(Don't quote me on this)
That's my $0.02
Old Aug 6, 2004 | 05:07 AM
  #27
PM-Performance's Avatar
Default Re: (CRX T-Si)
.7bar is 10.46psi. ill try that when i get the car back and se eif that helps.
Old Aug 6, 2004 | 05:09 AM
  #28
CRX T-Si's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">.7bar is 10.46psi. ill try that when i get the car back and se eif that helps.
My bad, I am not too familiar with this Bar crap. But I do somehow remember 1bar is around 15psi.
Keep us updated.
Old Aug 6, 2004 | 05:15 AM
  #29
will do. prob wont be till like next week sometime
Old Aug 6, 2004 | 06:39 PM
  #30
Siriuswerks's Avatar
It was creeping Before we put the boost controller. also Im running a deltagate and im gonna get the turbonetics evolution wastegate and see what happens from there.
the Boost controller is BRAND NEW. we have tryied all senarios. and it is a pain in the ***.
will keep updates
Boosted00
Jan 19, 2018 01:51 PM
alperx
Jan 24, 2012 12:22 PM
turbohatch96y7
Jul 12, 2009 01:52 PM
turbo se
Jun 13, 2003 11:33 AM
rbf351
Dec 17, 2002 06:10 AM
