Oil Return Line problem...
Old Aug 24, 2005 | 05:24 PM
StolenTeg's Avatar
Default Oil Return Line problem...
Okay so my downpipe is very close to my oil pan and there is not much room to run the return line. It basically is touching the downpipe and the pan itself, but there is one problem, when im on an even level ground it drain fine but once i go into a downhill level. The drive way i was in is about 20-30 degree angle and it burn a little bit of oil when the front of the car is point down. should i be worry about this or it should be fine since there aint much hill around my place.
Old Aug 25, 2005 | 03:40 PM
TheIntegraGuy's Avatar
Default Re: Oil Return Line problem... (StolenTeg)
I don't think you have much to worry about. I'd try to avoid downhill parking, but you can't help it if you're going down a hill..
Boosted_B_Series
Jan 2, 2007 09:42 PM
kameleon23
Oct 5, 2006 03:14 PM
scartail
Apr 16, 2005 06:06 PM
Racer X
Dec 1, 2002 02:34 AM
jdmciviceg
Apr 4, 2002 10:43 AM
