oil leaking from return line?
Old Sep 7, 2003 | 01:52 PM
k20em2's Avatar
Default oil leaking from return line?
I've got oil leaking from the return line( line from turbo to oil pan). Its a steel braided line. I've had the turbo on the car for a month nad this just started. Anyone know how this could've happened? also can I just buy another steel braided line and use that? any help would be appreciated thanks. [IMGhttp://www.theforumisdown.com/uploadfiles/0103/oil leak.jpg ][/IMG]
Modified by k20em2 at 2:47 AM 9/8/2003
Old Sep 7, 2003 | 02:07 PM
civictypenos's Avatar
Default Re: oil leaking from return line? (k20em2)
have you tried to tighten it?how close is the line from the DP?what kind of fittings are you using to attach the line?what kind of fitting on the oil pan,is it welded?
Old Oct 19, 2006 | 07:07 PM
civicSIracer96's Avatar
you got teflon on the treads?
Old Oct 19, 2006 | 07:24 PM
aaroboost's Avatar
edit: just trying to fix the pic. o well
PinoyDelS0l
Aug 30, 2009 12:43 AM
cameron4776
Mar 15, 2008 06:15 AM
Trigun
Jun 17, 2002 10:47 AM
