oil pan tapping vs pretapped pan
I'm gonna put an FMAX in my 95 GSR. What's the best and easiest/time efficient way to go? drop my pan and have someone weld fittings or go with an aftermarket like the Moroso with pretapped fittings? Or get a new OEM pan and have that one done before I even put the turbo kit on? Any ideas?
Just drill a hole into your pan and install a AN bulkhead fitting. It tightens against your oil pan allowing the oil to flow thru the fitting with no chance of leaking. Then finish it off with a steel braided line. This is what I'm doing with my install.
Go to a local hose/hydraulic dealer and purchase a "bulkhead" fitting. This is the same thing that is used on NHRA approved fuel cells. It can be installed without welding.
