oil pan drain placement
Old Jul 19, 2002 | 02:55 PM
nekkedR's Avatar
Default oil pan drain placement
hey guys, this is my first post in the FI forum, i have a 97 type R and i began my journey in the world of boost. i have a quick question,im peiceing my kit together an im waiting on my downpipe. i orded a an f-max downpipe for my car, i dont have it yet but i want to put my drain tube in my oil pan, does anyone have a pic of a DOHC 1.8 with a f-max dowpipe or can anyone tell me the optium place for this tube. id like to have everything built and then just put the downpipe on when it finally shows up.thanks in advance.
Eric
Old Jul 19, 2002 | 03:13 PM
b00stedsi's Avatar
Default Re: oil pan drain placement (nekkedR)
Are you talking about the oil return line? What drain tube on the downpipe?
Old Jul 19, 2002 | 03:27 PM
nekkedR's Avatar
Default Re: oil pan drain placement (turkish)
im talking about the drain line from the turbo to the oil pan, i dont want the oil liner to interfear with the down pipe(that i dont have yet). so i want to know where in my oil pan to weld the oil drain tube.
Eric
Old Jul 19, 2002 | 03:54 PM
HXMan's Avatar
You want it to look like this. (mine)
It is on a b16, and it is the drag kit, but all lines should be similar. Try to keep the hole in the oil pan high, and allways have the line downward sloping!
[Modified by HXMan, 6:55 PM 7/19/2002]
Old Jul 19, 2002 | 05:13 PM
rjardy's Avatar
Default Re: oil pan drain placement (HXMan)
Hey your return looks really nice!
Rob
Old Jul 19, 2002 | 09:26 PM
Flamenco-T's Avatar
Default Re: oil pan drain placement (rjardy)
as high as possible and make sure you don;t have it welded in the way of the oil pan bolts and studs...otherwise you won;t be able to mount the bolts and buts..
Old Jul 19, 2002 | 09:47 PM
justagsr's Avatar
Default Re: oil pan drain placement (Flamenco-NA)
Nice pics and fittings.
Check these threads for a little light reading too and I hope they help:
https://honda-tech.com/zerothread?id=206308
https://honda-tech.com/zerothread?id=168074
https://honda-tech.com/zerothread?id=157278
Old Jul 19, 2002 | 10:04 PM
b18bvudoo's Avatar
New User
thats what i did
my oil pan is held on by one less bolt now
its cool, no leaks so far.
Old Jul 19, 2002 | 10:44 PM
B20LS-T's Avatar
New User
Default Re: oil pan drain placement (b18bvudoo)
I would wait. With mine(custom 3" DP) it was a close fit and if you put the oil line in the wrong place, it will not be fun doing it over.
Old Jul 21, 2002 | 02:07 PM
HXMan's Avatar
Thanks!
Oil lines are a PITA though....
Old Jul 21, 2002 | 08:31 PM
ion_four's Avatar
hxman, how big is that DP? Is that the standard Fmax?
ashb82
Mar 22, 2010 12:50 PM
rudebwoy
May 21, 2005 12:28 PM
fandango
Jan 20, 2005 06:20 PM
blackeg
Jun 6, 2004 07:55 AM
TurBoXBirD16
Mar 25, 2002 08:22 AM
