Oil feed line?
Old Aug 26, 2002 | 08:53 PM
wrXtian's Avatar
Default Oil feed line?
ok i plan on isntalling my turbo this coming weekend in my integra and i kinda have the idea of where the oil feed line goes, but what tool do i need to take this out so i can plug in my new line.. and is it difficult to remove?
thanks
Old Aug 28, 2002 | 04:32 PM
wrXtian's Avatar
Default Re: Oil feed line? (xjdm94x)
anyone?
Old Aug 28, 2002 | 04:47 PM
OKSolSi's Avatar
Here is a big ******* tip I found out myself AFTER going thruogh the hassle of finding the oil tap tee measurement myself for my custom turbo. The store "AutoZone" if you have one around you has something called a "tee kit" that I saw one day while looking for some oil for my car. I shat my pants because it took me so long to find the oil tap measurement.. I made ilke 95 trips to Home Depot. Their "tee it" fits honda cars and should get you going. Then all you need is the steel braided hose which you can pick up at a hardware store labeled "Dishwasher Hose". Good luck bro.
BTW, no its not hard to remove. You may have to get rid of some mounting brackets to be able to get up in there though. I had to move a cat bracket that wasn't even holding the cat in place really so I never put it back on. Also, remove your oil filter so you have more space. Again, good luck.
[Modified by OKSolSi, 1:48 AM 8/29/2002]
Old Aug 28, 2002 | 07:10 PM
wrXtian's Avatar
Default Re: Oil feed line? (OKSolSi)
what kinda tool do i need to remove it.. i heard a 23 mm socket??
Old Aug 29, 2002 | 12:01 PM
OKSolSi's Avatar
24mm deep socket
Old Aug 29, 2002 | 12:24 PM
DeepSi's Avatar
i think i used a 15/16 deep well socket and it worked fine. i will make sure though
-deepsi
Old Aug 29, 2002 | 12:48 PM
Scott - 93HB Si's Avatar
Default Re: Oil feed line? (DeepSi)
It was a 24mm (socket works best, also wrench works if you have enough room back there). As for the thread, 1/8" BSPT works perfectly.
Old Aug 29, 2002 | 07:26 PM
pelotudo's Avatar
Default Re: Oil feed line? (Scott - 93HB Si)
It depends on the OPS you are using. My stock one (ZC) used a 24mm, but the new one I got at Pep Boys was a 23mm, and the 2nd new one I got (Long story) from Discount was 7/8" (Prolly 23mm...but they didn't have a 23mm deep socket for me to try).
jB
Old Aug 29, 2002 | 09:57 PM
94cxhybrid-T's Avatar
New User
i am in the middle of my install and i did the oil feed today and i used a 15/16ths deep socket 12pt. HTH
[Modified by 94cxhybrid-T, 10:58 PM 8/29/2002]
Old Aug 30, 2002 | 06:50 AM
DeepSi's Avatar
Default Re: Oil feed line? (94cxhybrid-T)
Yeah the one i had to use was the 15/16" 12pt deep socket. Maybe the 24mm is the same size almost? 15/16 = .9375 inches and 24mm = .94488. Close, i wonder which one is the correct size.
-deepsi
MrDomino
Jul 7, 2010 08:30 AM
iHOPEyouCHOKE
May 27, 2006 09:24 AM
slo_crx
Oct 6, 2004 08:30 AM
mattcalica
Aug 16, 2003 06:20 AM
Ri5e
Feb 17, 2002 02:20 PM
