Oil cooler question
Old Jun 5, 2008 | 09:32 AM
CTR_B's Avatar
Default Oil cooler question
I was wondering if the way the oil lines are ran would work ( as in enough PSI) Also would this be a practical addition or just a waste of time?
Modified by CTR_B at 12:53 PM 6/5/2008
Old Jun 5, 2008 | 11:53 AM
CTR_B's Avatar
Default Re: Oil cooler question (CTR_B)
No one uses an oil cooler?
Old Jun 5, 2008 | 12:48 PM
GT35R_EF's Avatar
Make mine whatever you want
A lot of people don't use them because of the extreme drop in pressure that some people see. I'm sure some are using it but you most likely won't find many. I think it just comes to weighing the positives vs. negatives. Good luck, and it would work but I would just be worried about the drop in pressure.
Old Jun 5, 2008 | 03:28 PM
CTR_B's Avatar
Default Re: Oil cooler question (GT35R_EF)
Thanks man, I am interested in running a cooler just dont know how I want to run the line as of now. Im thinking I will run the cooler seperate from the turbo feed line. I know this means I will have two more lines running threw the bay but I'm thinking of using an oil sandwich plate for the cooler it's self. This i don't think would cause a drop in psi like it would if I were to run it from the block to the cooler then the turbo.. IDK only time will tell I guess
carlos8
Sep 7, 2011 01:08 AM
HighRevn
Oct 24, 2006 07:18 AM
zexifiedlude
Dec 7, 2005 11:07 PM
92 4doorsleeper
Sep 17, 2005 09:16 AM
screen_name
Apr 23, 2005 07:22 AM
