precision sc34 oil restrictor
Old 09-06-2011, 09:31 AM
carlos8's Avatar
Default precision sc34 oil restrictor
hi, i'm swaping my old 50trim garrett running a .065" restrictor and 4an line for
a sc34. Do i need the restrictor or not i searched and theres a lot of different
opinions. The shop i bougth the turbo say not to use one with 4an. But i see
in our shop a lot of precision smoking brand new and fixed with restrictor.080"
cause of the high honda oil pressures. The guy say he is 100% sure (but is a race shop not precision).
Any help will be appreciate.
thanks
Old 09-06-2011, 09:38 AM
rich7777's Avatar
Default Re: precision sc34 oil restrictor
I'm pretty sure you'll need to run the restrictor. Hold on for other opinions though as i'm not a turbo expert.
Old 09-06-2011, 10:30 AM
Moderator
TheShodan's Avatar
depends upon oil pressure that you have.
Old 09-06-2011, 11:41 AM
codenamezero's Avatar
Doesn't hurt to run an oil restrictor, if your line pressure is high and having too much oil flowing through, the restrictor will do its job, otherwise it will just flow less than or equal to the amount allowed through the restrictor...
Old 09-06-2011, 12:03 PM
sc34dc4's Avatar
thanks
I'm running the same turbo in question. This is just my personal experience and is not exactly for everyone's setup. Precision tech told me NO restrictor with a -3 line. I've ran it this way for 2yrs + and the turbo was bought used from a friend and he ran no restrictor on it either. -4 is obviously bigger so I would think a restrictor would be needed. Also as mentioned by the shodan it all depends on oil pressure.
Old 09-06-2011, 01:37 PM
carlos8's Avatar
my oil pressure is 80psi at WOT and the feed line and oil gauge are connected
to a GE sandwich plate. What do you think it's better .080" or .100" restrictor,
i think .065" it's to small.
Old 09-06-2011, 06:19 PM
Moderator
TheShodan's Avatar
Well, you'd be wrong on that. .065" is best for pressures over 80psi at WOT or cold start for Garrett and Precision journal bearing turbochargers
Old 09-06-2011, 09:40 PM
dantamparacer's Avatar
call precision and ask
Old 09-07-2011, 01:08 AM
carlos8's Avatar
thank you: shodan, i see you have a lot of expierence and many other posts
helping people. I'll keep my .065" rest. and 4an line.
hondahead'
11-11-2009 03:59 PM
Boosteddb8
08-17-2006 02:35 PM
screen_name
04-23-2005 07:22 AM
wade
10-10-2004 07:38 PM
killa_lude
08-21-2004 11:44 AM
Quick Reply: precision sc34 oil restrictor
