waste gate dump valve always open?
Old Jun 5, 2008 | 01:45 PM
TheWhiteHatchProject's Avatar
Default waste gate dump valve always open?
i recently put a turbo system back together and had an issue that id like some help with. it has a tial wastegate that has a plumbed dump tube to the bottom of the block. when i started to drive the car i noticed that the exhaust note was loud and i found that was because there was exhaust coming out of my dump tube. thats not always supposed to be open, correct? what could i have possibly hooked up wrong to have this happen?
Old Jun 5, 2008 | 01:49 PM
inspyral's Avatar
Did you install the valve seat?
Old Jun 5, 2008 | 02:27 PM
Default Re: (inspyral)
please, bare with my inexperience here. i took the wastegate off of the manifold and removed the dump valve tube when it was in working order. i simply bolted the wastegate back on and reinstalled the dump valve tube and now i have this. when a wastegate is uninstalled are you required to install a valve seat when you reinstall it?
Old Jun 5, 2008 | 02:37 PM
inspyral's Avatar
The valve seat looks like this:
It goes in the bottom of the wastegate and sits on the mounting surface of the manifold. It can sometimes fall out when removing a wastegate from the manifold. Doublecheck that yours is still there.
Old Jun 5, 2008 | 04:06 PM
ah, so in other words the valve seat is what seals the wastegate to the mounting flange...got it
appreciate the help
lucas
Modified by TheWhiteHatchProject at 1:27 AM 6/6/2008
Old Jun 5, 2008 | 04:13 PM
-[95cxhatch]-'s Avatar
hey look at what I found in the big blue tub....
Old Jun 5, 2008 | 04:15 PM
Default Re: (-[95cxhatch]-)
LOL
Old Jun 5, 2008 | 04:25 PM
Default Re: (TheWhiteHatchProject)
right on inspyral, thanks again
4dek
May 27, 2008 10:55 PM
Metal Head
Sep 14, 2006 01:16 PM
