The Official SOHC Supercharger thread...
You need it in all the months. I have my Hondata s300 to activate it whenever the IAT get over 100. When it was low 40s outside I would still cruise and have IAT's over 100 so it is always needed.
Mono care to post some pics of the setup? I've been looking into it when i build a proper D for the JRSC and get a smaller pulley machined for more psi
Here are the pics I have it was a rush install and the last pic is the difference in a b7/z6 pulley and a y8 pulley
found this old video I was on the y8/3.4 pulley combo. I made 170/131 with the z6/3.4 setup. I had a 300lb passenger and the other car had a 260lb passenger. Turbo ls in other car made 220/200 I want to say it was a 40 roll. I shift into 3rd around 75mph that when he pulls away. http://youtu.be/zvI4R78eAl0
There is some more info and pics for you. Im on a completely stock motor that I have rebuilt for the 2nd time. Its currently a 76mm bore with stock p28 pistons. Only thing I have done is opened the ring gaps of the top ring only to .018 and 2nd ring was .020. they came 14/20. So far all npr honda rings I have measured were .014 top and .020 2nd. Now what I found out was the npr rings that are sent with vitaras for the g16 engine code are reversed gap. Top ring was gaped larger then the 2nd ring.
went 13.9@99 last friday with a 2.20 sixty the DA was 3200. My friend went 14.4 with his eg hatch gutted with a stock b20 on a 50 shot. Raced him on the street later from a 20 and this was the outcome. http://youtu.be/2Vo5bgybzFE
Had a cold bottle but this is me racing my friends car that makes 425hp to the ground and runs mid 12's http://youtu.be/s51sesWaVFU
So last night clutch started slipping. Stage one not enough now. Not bad though for a 195hp rated clutch I am making 230whp. Time for the new motor and stage 3 clutch.
Clutch still slipping so I was slow shifting. Racing a 03 svt cobra claiming 490 hp to the wheels.
http://www.facebook.com/video/video....20697891316051
