The Official SOHC Supercharger thread...
OK I've decided to get off my lazy *** and get my motor completed so I can throw my SC on it. I still need a couple of parts to finish it and need some advise. I'm would like to go with low boost high comp setup.
My setup:
A6 Block - Freshly rebuilt
ZC DOHC Pistons
A6 Head - Rebuilt
What additional would be good for this?
ARP
Head gasket - who/thickness
I also have a spare Z6 head. Any benefits with a Vtec vs. Non-Vtec head?
Would a close geared ZC tranny and SC mix well?
Thanks
My setup:
ZC DOHC Pistons
A6 Head - Rebuilt
ARP
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumpkinkidd »</TD></TR><TR><TD CLASS="quote">My setup:
ZC DOHC Pistons
A6 Head - Rebuilt
ARP
arp head studs. any thickness headgasket, i'd go with a stock metal unit. your pistons will bring the compression up. no benefit with vtec. all the higher hp figures have all been non-vtec. yes, close geared trans would work great. its not a turbo, no need for longer gears.
a SCed car feels like a super strong NA car.
ZC DOHC Pistons
A6 Head - Rebuilt
ARP
Thanks for your help rmcdaniels & STREETWERKZ. I knew that an EMS would be what I needed. I am going for the Hondata S300 (ODB1-ODB2 conversion) that should do, correct? Also ditch the FMU and run just the FPR, that's what you suggest. Cool, Thanks.
Now about raising the boost? What do you all suggest: OE Y8 crank pulley, new nose pulley, or boost upgrade kit?
The boost upgrade kit--I thought I had read in previous post and correct me if I'm wrong, had been discontinued. If I am wrong and it is still available would I even use the BTC it comes with after the S300?
Sorry for my ignorance, but I just want to see what the best way is to reach this engines potential.
One more ?, Will I need larger injectors + fuel pump, I know you are going to say YES, but is that over-kill. Its just a SOHC.
Thanks again for all your help.
Modified by civicslug at 11:05 AM 12/8/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">rexman is selling a kit for $1100</TD></TR></TABLE>
Thanks!!
Thanks!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicslug »</TD></TR><TR><TD CLASS="quote">Thanks for your help rmcdaniels & STREETWERKZ. I knew that an EMS would be what I needed. I am going for the Hondata S300 (ODB1-ODB2 conversion) that should do, correct? Also ditch the FMU and run just the FPR, that's what you suggest. Cool, Thanks.
Modified by civicslug at 11:05 AM 12/8/2006</TD></TR></TABLE>
haha we have to over kill our little single cam's to make them strong lol. I have a 3.6 snout pulley and I just picked up a y8 crank pulley which should put me at about 10lbs. Another point to touch on is the injectors to make sure there will be a good flow of gas when the boost sets in. I am still waiting on this *** hat that i bought my dsm 450's from, once they get here i will throw the y8 on and baby it up to the tunner. OBD0 FTW turboedit lol. A good way to pull out our engines potential from what i have read is to mill the head to up the compression SC's love that. Check out tad's formula that i have in my sig it is actually a great formula for single cam sc power. Best of luck with your build glad to have another member to the board
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8atman »</TD></TR><TR><TD CLASS="quote">
I have a 3.6 snout pulley</TD></TR></TABLE>
Where'd ya get it?
Where'd ya get it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Where'd ya get it?</TD></TR></TABLE>
^^^yeah you can get the 3.2 from endyn I got the 3.6 from moss motors its a 4rib to
After tax and shiping it was $97.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveb91 »</TD></TR><TR><TD CLASS="quote">JR or endyn.
I want proof of this raised compression thing I have a extra head waiting!!!
anyways
</TD></TR></TABLE>anyways
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveb91 »</TD></TR><TR><TD CLASS="quote">Doesnt mean your not a newbie lol</TD></TR></TABLE>
Thats true, so is everyone else here, but yes im new at all this and im not a pro but im learning and it is a total pain when people keep putting me down for trying
typical honda expert tech lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Fly SI »</TD></TR><TR><TD CLASS="quote">Did you start a new name just to say that?</TD></TR></TABLE>
seems that way
seems that way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Ya, I have a 3.0 and a 3.4 from Endyn, as well as a Jackson 3.8, but I wanted a 3.6. Which application is the 3.6 from?</TD></TR></TABLE>
Back to the main point of this THREAD!!!
I got my 3.6 from moss motors the guy said it was the stock pulley that came off my model aplication so im assuming its the 88-91 but it doesnt make sense that its 4 rib oh well who cares. So anyone used a 3.6 and a y8 crank pulley? What kinda boost did that make? Thanks.
seems that way
Please explain how you "know" what you "know"?
From reading and from people tell you. I bet you didn't turn a wrench on your whole install.
I read your "install thread" ... looks to me like you were standing around while my brother did all of the work.
I'm not a CAR GUY, but I'm willing to bet I know more than you when it comes to how these things work. I'll even line up my spoked Monte Carlo up against your rust bucket and show you the ***-end all the way down the boulevard. All while I'm dumping and sparking out of the back.
seems that way
</TD></TR></TABLE>Please explain how you "know" what you "know"?
I read your "install thread" ... looks to me like you were standing around while my brother did all of the work. I'm not a CAR GUY, but I'm willing to bet I know more than you when it comes to how these things work. I'll even line up my spoked Monte Carlo up against your rust bucket and show you the ***-end all the way down the boulevard. All while I'm dumping and sparking out of the back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8atman »</TD></TR><TR><TD CLASS="quote">HEHEHE Hi Joe he is right I dont know whats up thats why I have a working SC in my car right now lol. you kill me
Jon. I'm Joe's brother.
Joe did all of the work from my understanding. You didn't listen to a thing he told you to do. and when things went wrong, you were the first to point fingers. If you were to open your ears more than you open your mouth, you probably wouldn't have run into the problems you have.
You say you have a running car right now, but from what i hear, it's BARELY running. Untuned, and you're still taking it to the canyons. Shoot, you didn't even know what fuel pressure to set your car at. I bet you stood there as Joe gapped your spark plugs. You don't have any knowledge as I've stated before. You read and regurgitate. Sure you took the blower off and put it back on, But only after you saw Joe do it 15 times up at his house.
BTW, Joe might have forgave you (even though he'll never help you again) but I haven't. If you couldn't tell.
I'll stay out of your precious thread now. Joe just wanted this screen name so he could post his progress pictures. If you got a problem, call my Brother and let him know.
</TD></TR></TABLE>Jon. I'm Joe's brother.
Thats true, so is everyone else here</TD></TR></TABLE>
Um not me LOL!!!! Anyways one thing I have always heard was the raised compression part but NOBODY has ever given me physical proof on this with the SOHC cars. If someone could give me some kind of proof then I would do it and give you guys a write up and dyno results. I am not ruining a head for nothing which is what it would be if it turned out to loose power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoClue »</TD></TR><TR><TD CLASS="quote">Please explain how you "know" what you "know"?
I'm not a CAR GUY, but I'm willing to bet I know more than you when it comes to how these things work. I'll even line up my spoked Monte Carlo up against your rust bucket and show you the ***-end all the way down the boulevard. All while I'm dumping and sparking out of the back.</TD></TR></TABLE>
ok well im official over it
here is my continued install thread link...http://www.d-series.org/forums//showthread.php?t=54755
that was when i got my car back home and fixed everything. I installed my SC myself did everything myself when I got it back down to my house. This whole thing is making me sick. Im out good luck to you and your career and all that fallows, Merry chirstmas.
I read your "install thread" ... looks to me like you were standing around while my brother did all of the work. I'm not a CAR GUY, but I'm willing to bet I know more than you when it comes to how these things work. I'll even line up my spoked Monte Carlo up against your rust bucket and show you the ***-end all the way down the boulevard. All while I'm dumping and sparking out of the back.</TD></TR></TABLE>
here is my continued install thread link...http://www.d-series.org/forums//showthread.php?t=54755that was when i got my car back home and fixed everything. I installed my SC myself did everything myself when I got it back down to my house. This whole thing is making me sick. Im out good luck to you and your career and all that fallows, Merry chirstmas.
