OBX LSD?
Old Aug 17, 2004 | 03:26 PM
  #126
Keith P's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">I'm always broke, but asked Phantom Grip for a test unit, they denied me.
Guess they knew I'd break it with my AWESOME SOHC power! </TD></TR></TABLE>
haha, I'm sure thats why they didn't "give" you one.. why don't you ask OBX for a sample and a performance guarantee
Old Aug 17, 2004 | 04:07 PM
  #127
14bcoupe's Avatar
Default Re: (Keith P)
wow your third gear broke in pieces and the lsd is still fine, hmmmmmm making my decision a lot easier.
Old Aug 18, 2004 | 01:45 PM
  #128
Keith P's Avatar
Default Re: (14bcoupe)
no decetn tests yet? seeing a gear shatter still doesn't testify to the lsd's strength.
Old Aug 18, 2004 | 03:15 PM
  #129
Sliced Beard's Avatar
someone send one to Chad.......he was able to bust a Spoon LSD....see if he can break this one
Old Aug 19, 2004 | 04:53 PM
  #130
BrokeLude's Avatar
Default Re: (dirtyd463)
I'm gonna be working under the car next week and will probably slap in a phantom at the same time. It's a lude H22a1, only slightly modded, and will never see more than 225 or so at the crank with the mods I may eventually do.
Couple questions:
Looks like I can just drop the axles and get to the diff through the cover without dropping the tranny. Is that correct?
I'm thinking that the normal springs that come with the kit should be fine for me. Anybody recommend going for the upgrade springs?
Old Aug 19, 2004 | 05:04 PM
  #131
Default Re: (BrokeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna be working under the car next week and will probably slap in a phantom at the same time. It's a lude H22a1, only slightly modded, and will never see more than 225 or so at the crank with the mods I may eventually do.
Couple questions:
I'm thinking that the normal springs that come with the kit should be fine for me. Anybody recommend going for the upgrade springs?</TD></TR></TABLE>
hahaha.....you still have to remove the transmission and open the case in order to install a Phantom Crap open diff modifier.........and i guarantee that you will not have a fun time removing the tranny on your Lude, especially if you have never done it before
Old Aug 19, 2004 | 05:16 PM
  #132
BrokeLude's Avatar
Thanks dude. If that's the case then I'll wait on that. It's hot as hell here right now, so it will be a project for the fall I guess...
Old Aug 19, 2004 | 05:26 PM
  #133
I highly suggest that you not get a Phantom Crap(Grip) because it is called Phantom for a reason
Old Aug 19, 2004 | 05:36 PM
  #134
BrokeLude's Avatar
I'll see what the Quaife witch brings me for halloween...
Of course they cost so damn much that she will probably make me pay most of it...
Modified by BrokeLude at 7:04 PM 8/19/2004
Old Aug 19, 2004 | 05:52 PM
  #135
adictionbass's Avatar
subscribes to thread...
Old Aug 19, 2004 | 07:45 PM
  #136
Joseph Davis's Avatar
T-minus how much? and counting until 600 whp dragstrip test....
Old Aug 19, 2004 | 07:53 PM
  #137
Quad-Damag's Avatar
Default Re: (J. Davis)
ya i might be buying one soon
Old Aug 20, 2004 | 10:13 AM
  #138
DaveF's Avatar
Default Re: (Quad-Damge)
they making these for b series..id like to pick one up asap.
Old Aug 20, 2004 | 04:40 PM
  #139
C_I_V_I_C's Avatar
UPDATES?
Old Aug 20, 2004 | 08:54 PM
  #140
If hybrid hatch's 600 whp +slicks test goes off this weekend without a hitch, I plan on ordering one Monday and doing some "beta" testing.
250-300 whp, and I'm the most abusive driver you've ever seen.
Old Aug 20, 2004 | 09:39 PM
  #141
HYBRID_H@TCH's Avatar
ok ok ok..its results time!!!!
I made 2 pass's tonight and both of which where on 28+psi of boost with the 50 shot from the nitrous flowing..I launched at 7K rpm off the 2 step and it took it like a man!! car went dead straight and hooked so good I was bogging at 7000 rpm!!!
off the 2step I was seeing 18 psi out of the hole and the nitrous would kick it at 43 mph (hondata set which is high 1st gear with a 9800 rpm rev limiter) so if any of you want to run one..I would not hestiate!! I love mine and it has been thru more punishment than I thought it could take..but it took it and we still drove home!!!!
BTW best run of the night was a 11.43 @ 144 mph!!!!! just need to learn to drive it with the NAWZ flowing..LOL
Old Aug 20, 2004 | 09:44 PM
  #142
gots_a_sol's Avatar
[will smith]i gotta get me one of these![/will smith]
Old Aug 20, 2004 | 09:55 PM
  #143
Quad-Damag's Avatar
Default Re: (99Hybrid_Hatch)
Sweet, new setup is asking for one
Old Aug 21, 2004 | 01:15 AM
  #144
SoEvoL's Avatar
looks like it just got added to my next transmission upgrade list
Old Aug 21, 2004 | 02:01 AM
  #145
XDEep's Avatar
Default Re: (JDMCrx89)
do you guys think it would be more likely for the spider gears and/or splines where the axles go in to wear out slowly and fail, or just crack at once and fail completely?
how long would it need to last to satisfy you for the price? im thinking 1.5-2years..
Old Aug 21, 2004 | 02:37 AM
  #146
Default Re: (XDEep)
if I can get 100 pass's down the track and still daily drive it..its justified for me
Old Aug 21, 2004 | 06:30 AM
  #147
Default Re: (XDEep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XDEep &raquo;</TD></TR><TR><TD CLASS="quote">do you guys think it would be more likely for the spider gears and/or splines where the axles go in to wear out slowly and fail, or just crack at once and fail completely?
how long would it need to last to satisfy you for the price? im thinking 1.5-2years..</TD></TR></TABLE>
No spider gears in an LSD, stunna...
Still not sure how the unit holds up to long term abuse, I'm thinking metal fatigue when I say that, but the design appears robust enough.
I'm going to say a cross between hybrid hatch's and XDEep's opinion on desired longevity is where I am at... I'll be driving it on the street as much as using it as the shop drag car.
Old Aug 21, 2004 | 07:10 AM
  #148
I am going to take a pic of what the inside of a helical LSD looks like and you will understand why they are almost indestructable
Old Aug 21, 2004 | 08:39 AM
  #149
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
I see 4 spider gears........
Old Aug 21, 2004 | 08:47 AM
  #150
95GSRTT
Guest
Posts: n/a
Damn nice! I think I might be getting one of these, once i figure out which tranny im gonna go with lol. If anyone has some results post them up.
