obd2 b18b1 what a good motor build?
So i just bought this b18b1 today and it doesnt have cams or cam gears on it so im gonna need them also.
I wanna build the motor for boost and am looking for 450-500hp
Whats a good set of pistions and rods does the heads need to be built to run some decent amount of boost i know the d series can hold 25psi on the head stock. Whats a good set of cams? Where can i get these at ?
official honda whore
Re: obd2 b18b1 what a good motor build?
read read read and read some more, you could have found out your answer if you looked down the page
for a basic build for 400whp this will get you there
get the block and head resurfaced
eagle rods
9:1 cp pistons (81.5mm)
block bored/honed to piston specs
oem rod/main bearings and thrust washer
new oil pick up gasket
new oil pan gasket
new head gasket
arp head studs
new rear main seal
new water pump
new timing belt/tensioner
and that should be it
add a 57 or 60 trim turbo and you have a 400whp pump gas street car
eagle rods
new oil pan gasket
new head gasket
arp head studs
new rear main seal
new water pump
