not building boost
Old Apr 6, 2009 | 05:58 PM
h22civicek's Avatar
Default not building boost
hey guys buddy had a turbo kit put on his car , but not building any boost wastegast is hooked up right , any ideas?
Old Apr 6, 2009 | 06:18 PM
Turbo-LS's Avatar
Default Re: not building boost
does the car have a catalytic converter on it? If so is it old and clogged? is there a clogg in the charge pipe? is the turbo seized?
Old Apr 6, 2009 | 06:25 PM
jdm inc's Avatar
vacuum lines all hooked up?
Old Apr 6, 2009 | 06:35 PM
Turbo-LS's Avatar
vac lines wont cause it to NOT build boost, that would cause to much boost
Old Apr 6, 2009 | 06:46 PM
h22civicek's Avatar
Its straight down pipe. I will check for the clog in the charge pipe, is there anything else you think it could be?
Old Apr 6, 2009 | 07:02 PM
Turbo-LS's Avatar
open DP and it wont build boost? WG stuck open or no spring in it? boost leak PRE turbo
Old Apr 6, 2009 | 07:05 PM
jfoster's Avatar
Kinda had the same deal when I first got my set up together, turned out my tial 38mm had a 3psi spring in it.
Old Apr 6, 2009 | 07:29 PM
B16Civic93's Avatar
make sure the turbo is spooling(can you hear it spool when you drive?) check for leaks in the charge pipes, make sure the bov isnt stuck in hte open position, and like mentioned above check the spring rating on the wastegate.
Old Apr 6, 2009 | 07:42 PM
Silva Bullit DC4's Avatar
Are you revving at a standstill, or are you driving the car while trying to build boost?
thegatekeeper14
Jul 6, 2010 12:53 PM
turbo-crx
Jan 24, 2009 09:06 AM
1sic3dr
Aug 11, 2007 03:28 PM
SPOOLINmatt
Apr 16, 2005 10:13 PM
lvf03
Mar 13, 2004 01:57 PM
