turbo take a dump?
Old Jan 23, 2009 | 05:00 PM
turbo-crx's Avatar
Default turbo take a dump?
its not making full boost. It makes like 5-7 psi only now, i didnt find any boost leaks or popped off charge piping. the shafts have alittle play but not much on comp and ex side. it doesnt smoke or anything. Any ideas would be appreciated guys.
Old Jan 23, 2009 | 06:06 PM
keving85's Avatar
Default Re: turbo take a dump?
check your spring on the wastegate>>???
Old Jan 23, 2009 | 06:22 PM
SovXietday's Avatar
A boost leak that will only allow 5-7psi is going to be small. You're better off doing a boost leak test than just pulling at couplers blindly.
Old Jan 23, 2009 | 07:13 PM
tegman23's Avatar
1.You should try making a boost leak tester, I made one for a couple bucks...sounds like you may have a tiny leak...
2.check your wastegate vacum sources, and make sure its opening properly
3.also are you running a boost controller?
Old Jan 23, 2009 | 08:02 PM
turbo-crx's Avatar
no boost controller, just wastegate spring. How do you make a boost leak tester?
Old Jan 23, 2009 | 10:57 PM
TehGhett0P1mp's Avatar
Google is your friend..
http://www.vfaq.com/mods/ICtester.html
Old Jan 24, 2009 | 06:52 AM
turbo-crx's Avatar
If thr turbo was blown would it make any boost?
Old Jan 24, 2009 | 09:06 AM
LastGenEK's Avatar
Your turbo sounds ok, Check over the charge pipes and wg spring
Sorry im no help haha
nychonda
Jul 1, 2009 04:37 PM
playahwitgame
Sep 19, 2006 09:08 AM
turbo95eg6
Jun 12, 2005 12:15 PM
crispydee
Oct 17, 2004 10:47 AM
Snafu-Si
Mar 5, 2002 02:07 AM
