not holding boost.
Old Mar 12, 2004 | 03:57 PM
lvf03's Avatar
Default not holding boost.
This is my problem.the wastegate doesn't hold boost at all.I'ts a 38mm deltagate{brand new} with a 9pound spring on a ssautochrome{i know, but thats what i got for now } manifold. Do you guys think that the angle of the wastegate on the mani. can be the problem.Thanks for the help
Old Mar 12, 2004 | 04:26 PM
b16ahybrid's Avatar
Default Re: not holding boost. (lvf03)
Hey buddy how about the rest of your set-up.
Old Mar 12, 2004 | 04:30 PM
turbo*s2k's Avatar
Default Re: not holding boost. (b16ahybrid)
What do you mean by not holding boost? Do you a have electronic boost controller?
Old Mar 12, 2004 | 04:49 PM
1bar's Avatar
Default Re: not holding boost. (TurboChrgd_Civic)
are you sure there is no leak in the charge pipes? Will it go into boost at all??
Old Mar 12, 2004 | 04:58 PM
blown_LS's Avatar
Default Re: not holding boost. (1bar)
Get more detail on your setup. But when i first got turbo on my teg it didnt' hold boost so i tought it was wastegate, well it turned out i had leak on my charge pipe. So make sure you go through the charge pipes and see if you got any leaks there.
Old Mar 12, 2004 | 06:56 PM
lvf03's Avatar
sorry about that.b20vtec with hondata,t3/t4 turbo and like i said deltagate wastegate.Also a-pexi avcr.Get boost not a problem just can't get it to hold just keeps on riseing.At first i thought it was the avcr but removed it and it didn't solve the prob.Also no leaks in the pipes thats why i was thinking that it might be the angle of the wastegate on the manifold not allowing exhaust gas to reach the wastegate setup
b20 vtec
9:1 comp.
b16 head port and polished with 70mmt/b
darton sleeves
rc550cc
hondata s200
t3/t4 50ar comp 63 exhaust stage 3 wheel
kaaz lsd
255walbro pump
Old Mar 12, 2004 | 09:24 PM
b16ahybrid's Avatar
Default Re: (lvf03)
Sounds like a combination of the wastegate location and the wastegate. From what i hear, the deltagates are notorious for boost creep.
Old Mar 12, 2004 | 10:58 PM
1bar's Avatar
Default Re: (b16ahybrid)
was the wastegate new?
edit: switch wastegate with friend and see if the problem keeps going.
Old Mar 13, 2004 | 10:17 AM
lvf03's Avatar
it's not really boost creep it just doesn't stop it would go until the turbo would let. I let it go around 15psi
Old Mar 13, 2004 | 10:28 AM
MikeMAN's Avatar
Default Re: (lvf03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvf03 &raquo;</TD></TR><TR><TD CLASS="quote">it's not really boost creep it just doesn't stop it would go until the turbo would let. I let it go around 15psi</TD></TR></TABLE>
well if you keep letting go around 15psi, expect your motor to let go..very soon. Stop at 5lbs, dont just keep on looking at it rising. As far as your problem, deltagates + the combination of a horrible wastegate location could be part of your problem. I would dissasemble the deltagate to see if its working correctly.
mike
Old Mar 13, 2004 | 10:44 AM
DA-MAX's Avatar
what is bad wastegate positioning? we're having a similar prob on a friends car(not a Honda), the wastgate is at a a 45* angle facing down...would that be a problem??
Old Mar 13, 2004 | 01:57 PM
1bar's Avatar
Default Re: (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">what is bad wastegate positioning? we're having a similar prob on a friends car(not a Honda), the wastgate is at a a 45* angle facing down...would that be a problem??
ive seen alot of manifolds with terrible wastegate placement. I doubt its the placement. I would try switching wastegates and see if the problem goes away.
also do you have the wastegate hooked up right? Take some pictures for us.
nychonda
Jul 1, 2009 04:37 PM
turbo-crx
Jan 24, 2009 09:06 AM
teamrocket si
Feb 10, 2002 02:27 PM
Cyrio
Dec 4, 2001 07:00 PM
