Is my turbo blown??
Old Apr 21, 2006 | 06:20 PM
Vtecme92's Avatar
Default Is my turbo blown??
My To4E is about 2 yrs old, I drive my car only in the summer. Here's the funny thing.. I was planning to go tune my car again today. But there's not boost. And no it's not leak in the charge pipe. My turbo spins freely at idel and when you rev it up in spins faster. But I'm still not getting any boost. So I took off a charge pipe and cover it with my hand it and I had my brother rev up the car to got the turbo spool up. And I could still cover the charge pipe with my hand. Isn't it suppose to blow my hand off?? Is this **** blown....No oil coming out the exhaust side, no white smoke, or blue smoke.
Old Apr 21, 2006 | 06:49 PM
Mugencrxsir1's Avatar
Default Re: Is my turbo blown?? (Vtecme92)
The only thing I can think off, is that your wastegate might stuck open. Does your wastegate have continuous air coming out? Is your wastegate interal/external, check your spring, and opening. Other than that It sounds weird! If I spin freely, then your turbo should be just fine, I'm stumped!?
Old Apr 21, 2006 | 07:06 PM
Vtecme92's Avatar
Default Re: Is my turbo blown?? (Mugencrxsir1)
the waste gate is closed when the turbo is spinning at idle I can stop it with a small vaccum tube, should it be strong then that but I haven't tried it when I rev it up...
Old Apr 21, 2006 | 07:09 PM
CRXdan's Avatar
Its either a leak in oen of your charge pipes, your bov is stuck open, or soemthign along those lines. Does the turbo make a funny whining sound liek a ghost when you try to spool it up?
Old Apr 21, 2006 | 07:12 PM
ek_chris's Avatar
if it spins freely, no oil, doesnt make a loud whining noise and the WG isnt stuck open.. I would beat on a leak somewhere.
I Have an STD's Avatar
wrenchin'
your turbo isnt blown. check your charge pipes again. then check the wastegate again. thats about i could tell you.
Old Apr 21, 2006 | 09:44 PM
locash's Avatar
It takes exhaust gas energy to spool the turbo, reving in neutral won't do a whole hell of a lot for you. Hypothetically speaking, you could remove the hood from your car, sit on the valve cover, have your buddy drive it down the street full blast, and then put your hand over the charge pipe.
Note: I do NOT recommend doing this, as you may fall off the car and be run over, in which case, Darwinism applies.
Old Apr 21, 2006 | 09:59 PM
HamiltonRex's Avatar
Default Re: Is my turbo blown?? (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">It takes exhaust gas energy to spool the turbo, reving in neutral won't do a whole hell of a lot for you.
.</TD></TR></TABLE>
Yes, engine needs load to create boost usually.
Old Apr 22, 2006 | 08:01 AM
Vtecme92's Avatar
Default Re: Is my turbo blown?? (HamiltonRex)
I'll take it out for a drive and let you guys know.
Old Apr 22, 2006 | 11:29 AM
CRXdan's Avatar
hahaha. wellt hats kinda obvious.
Yah it definetley needs to be driven to build boost, unless you have one of those tiny pretend turbos (AKA t25)
Old Apr 22, 2006 | 02:00 PM
yee SERIOUS's Avatar
Default Re: (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan &raquo;</TD></TR><TR><TD CLASS="quote">hahaha. wellt hats kinda obvious.
Yah it definetley needs to be driven to build boost, unless you have one of those tiny pretend turbos (AKA t25)</TD></TR></TABLE>
pretend turbos? we're not talking about the tornado here
jonslam
Feb 26, 2014 11:57 PM
turb0teg
Aug 25, 2010 08:56 PM
RFd15bhatch
May 20, 2005 09:20 AM
mattcalica
May 26, 2004 11:48 PM
bottlefedintegra
May 10, 2004 07:52 AM
