Low Vac, Low boost?
Old Aug 25, 2009 | 11:28 PM
vtak2nr's Avatar
Default Low Vac, Low boost?
Hi,
Normally on my car, I would get -20hg at idle, and fully boosted is 15psi
Tonight I was booting it a little on the highway, felt a little slow, I looked at my boost guage and i was only reading 4psi
I pull off, get to a light, and see at idle i get maybe only -6hg, and when floored, maybe 1psi
You can still hear the turbo spool like a champ, car still drives pretty flawlessly, minus the boost
What could it be?
Would a faulty wastegate cause this?
Old Aug 26, 2009 | 01:25 PM
vtak2nr's Avatar
Default Re: Low Vac, Low boost?
bump
Old Aug 26, 2009 | 01:48 PM
got wide's Avatar
did you check all the vac/boost lines going to the IM? sounds like a manifold leak
Old Aug 26, 2009 | 02:11 PM
accord_raffi's Avatar
What's your car doing at idle? Sounds like a vacuum leak to me.
Old Aug 26, 2009 | 05:24 PM
boostedcivicsir's Avatar
Mr. Badwrench
if your vac dropped and the boost dropped at the same time, it has to be a vac leak. if they didnt happen at the same time, there could be 2 separate issues.
go over all your post throttle body vacuum fittings and gaskets. use some carb cleaner, spray around and listen for the rpm change.
Old Aug 26, 2009 | 05:42 PM
Turbo-LS's Avatar
sounds like a vacuum leak and a charge pipe came off or just the vacuum leak. generally you should be able to build more boost than that with just a vacuum line off thats why i think might be two things
Old Aug 26, 2009 | 11:23 PM
vtak2nr's Avatar
At idle the car is fine. Just my guage reads -6hg rather than the normal -20hg. RPMs dont fluctuate (as ive seen other cars with vacuum leaks do)
Infact the car still drives perfectly fine, minus the loss in power, it is still definately driveable
I tried looking//listening//feeling for a leak with the car idling but didnt find anything. Re-tightened all my boost pipes, same thing.
How would I go about checking a vacuum leak with everyday items? (i only have basic socket//wrench sets at home, nothing pro...)
Old Aug 27, 2009 | 12:39 AM
oodie's Avatar
He just told you a way
Old Aug 27, 2009 | 03:59 AM
Turbo-LS's Avatar
while the engine is running take a can of brake cleaner and spray around the inatek manifold where the vacuum portsd are and throttle body and where it meets the head. if the engine revs up find the leak source that way and your problem is solved.
if the engine isnt on a high idle then it probably doesnt have a vacuum leak and could just be a boost pipe is not connected OR you've lost compression in more than one cylinder. do at least a compression test on a warm engine and see what numbers you come up with. if you have a leak down tester than do a leak down as well
Ultra EK9
Feb 13, 2011 06:48 AM
ericstambaugh07
Jul 3, 2007 07:59 PM
1FastCoupe
Dec 10, 2006 08:33 AM
mkinpwrat12g's
Sep 29, 2005 02:33 PM
ash.zero
Jul 9, 2005 04:22 PM
