nitrous and pump gas
Old 12-16-2005, 06:37 AM
quikcivic's Avatar
Default nitrous and pump gas
my setup is a gsr block with stock sleeves and 12:1 compression, b16 head with S2S3 cams aebs intake 370 injectors smsp header, i wanted to use nitrous but is it safe to run a 75 single fogger wet shot on pump gas properly tuned, also iam a noob thanks i
i also searched but no luck
Old 12-16-2005, 02:13 PM
quikcivic's Avatar
Default Re: nitrous and pump gas (njallmotoref)
anybody?
Old 01-02-2006, 11:17 AM
turbolshatch's Avatar
i am gonna run a similar setup and would also like to know? does anyone have any input
Old 01-02-2006, 03:35 PM
mtber's Avatar
As long as the vehicle is properly tuned, you should be ok.
I would recommend a ems setup that supports nitrous plugins or a dual map chip setup etc.
Old 01-02-2006, 04:03 PM
1700anddroping's Avatar
Default Re: nitrous and pump gas (mtber)
here thisa will help you.pm me if you need more help in under standing it.
https://honda-tech.com/zerothread?id=1460144
harv
Old 01-02-2006, 04:42 PM
Default Re: nitrous and pump gas (1700anddroping)
thansk for the help
Old 01-02-2006, 04:52 PM
Default Re: nitrous and pump gas (turbolshatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbolshatch &raquo;</TD></TR><TR><TD CLASS="quote">thansk for the help </TD></TR></TABLE>
your welcome
jamescb77
04-01-2007 10:25 PM
01DC4
01-23-2007 06:49 PM
Cali4niaEk9
12-03-2006 09:05 PM
six7one
05-29-2005 09:06 PM
mischiefinnovations
09-20-2004 04:56 PM
Quick Reply: nitrous and pump gas
