****NITROUS BUILDERS**** I NEED HELP WITH MY SET UP!!!!!!!!!
I WANT 2 GO BIG ON NITROUS!!!!!!!!!! i want to know what do i change or do to Use as much NITROUS as i can On Race Gas on the Track on my All motor Setup!!!!!!!!
B20b block Stock Sleeves Block Guard 84.5mm Arias 11:8:1 Piston
Rods are Pinned (stock)
Type R water/Oil Pump
Ctr Pully
Custom Head Gasket for High Compression
B16 Head Ported/Polish Full Omni Valvetrain
Milled HEAD 440Injectors
Jun 3's or Have Custom DH RACING CAMS
Rage Header 2.0 Big Tube
Want to Know what Spark Plugs to run? Wat to Change !!!!
Wats biggest i can go On Squeez?
What System To BUY???????????
Ctr Pully
Re: (Cali4niaEk9)
Your questions are pretty general and honestly no one can tell you what shot is safe to run on your car. Personally, I would go with a Zex/NX/NOS/whatever brand wet kit with a bottle warmer and run a 100 shot. Pick up a 255 lph fuel pump, bkr7e plugs, Mallory Hyfire ignition box (this box comes with a built in rpm window switch and push button timing retard), and tune it on a dyno.
Ok i do have a 255 lph Fuel pump in my car or do i run a second one for the Nitrous? I read that a guy in his setup with 14:1 Comprssion with a 200 shot!!!!!!!!!! What would i need to make it a All NITROUS Trac Setup?
Re: (Cali4niaEk9)
You shouldn't need two fuel pumps. If you want to go with a big shot, you'll need a fully built motor and a direct port setup. Read this thread to see what other guys with big n2o systems do...
https://honda-tech.com/zerothread?id=1460144
Modified by HandoEX at 2:41 PM 12/3/2006
