newest uberdata released
Old Nov 11, 2003 | 11:47 AM
  #851
toxicshit's Avatar
Default Re: (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote"> good info! </TD></TR></TABLE>
Thnx no problem!!
i live 5 minutes form the german border. so in about 5 min im on the german autobahn ( hiway ) and you drive as fast as you want on the german autobahn ( not on all places but some places you can). so i can test enough
Old Nov 11, 2003 | 01:49 PM
  #852
dabrown's Avatar
Default Re: (toxicshit)
Guys anyone have a good contact for Blake (Uberdata Creator) It's very important that I get a hold of him.. Thanks
Old Nov 11, 2003 | 02:18 PM
  #853
falcongsr's Avatar
What is this crap?
Default Re: (dabrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabrown &raquo;</TD></TR><TR><TD CLASS="quote">Guys anyone have a good contact for Blake (Uberdata Creator) It's very important that I get a hold of him.. Thanks </TD></TR></TABLE>
he is in the process of moving but i will see if he is around.
Old Nov 11, 2003 | 03:25 PM
  #854
Joseph Davis's Avatar
Contact B? LOL, he's available when he wants to be available. If you'd care to state your business, he'll probably get ahold of you if it interests him.
Old Nov 11, 2003 | 04:47 PM
  #855
phresh_5's Avatar
Problem solved, it wasn't my soldering. I forgot to disable the knock sensor
Anyone know how much fuel I need to cut on the P28 map to make it run like stock (no boost) on a Z6? I already tried -15%, still rich and bogs when I punch the gas. VTEC and FTL work fine.
Old Nov 11, 2003 | 04:57 PM
  #856
dabrown's Avatar
Default Re: (J. Davis)
http://clubboost.com/forum/ind...try58
Old Nov 11, 2003 | 05:32 PM
  #857
Default Re: (phresh_5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phresh_5 &raquo;</TD></TR><TR><TD CLASS="quote">Problem solved, it wasn't my soldering. I forgot to disable the knock sensor
Anyone know how much fuel I need to cut on the P28 map to make it run like stock (no boost) on a Z6? I already tried -15%, still rich and bogs when I punch the gas. VTEC and FTL work fine. </TD></TR></TABLE>
What size injectors you running? Because the only time I've seen my P28 basemap not run like stock, on a stock engine, the guy had his IAT and purge solenoid plugs reversed. P75/P72 code is very sensitive to IAT.
BTW, dabrown, I forwarded your heads up. B's an asshat.
Modified by J. Davis at 9:45 PM 11/11/2003
Modified by J. Davis at 10:24 PM 11/11/2003
Old Nov 11, 2003 | 05:46 PM
  #858
phresh_5's Avatar
[QUOTE=J. Davis]
QUOTE]
Everythings stock, I just want to get uberdata running my car stock first then change the fuel tables for bigger injectors. The first time I tried it I got a Code 0, then reset, tried again with different chip (less fuel), then I got a Code 20 (IAT) and Code 0. These were both with knock sensor enabled. After taking knock out it runs with no CEL but its rich. I can see slight black smoke out the exhaust and I can tell by the way the car sounds and the Air/Fuel meter. The only wires I've added to my ecu harness are for VTEC and a T on the O2 wire for the A/F meter.
Old Nov 11, 2003 | 06:57 PM
  #859
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabrown &raquo;</TD></TR><TR><TD CLASS="quote">http://clubboost.com/forum/ind...try58</TD></TR></TABLE>
Well that is certainly interesting. If it involves monitory compensation, im sure he will respond. Cool that a corporation like that is gathering info on ECU hacking.
Rob
Old Nov 11, 2003 | 07:04 PM
  #860
dabrown's Avatar
Default Re: (rjardy)
Yea they are really cool, I gave them the link to this thread along with the pgmfi.org. I have purchased 2 pocket programmers from them without any issues.. Now I am thinking about the romulator so I dont have to keep running upstairs.
Old Nov 11, 2003 | 07:18 PM
  #861
falcongsr's Avatar
What is this crap?
all i got from them was the romulator cause i have access to a burner. romulator!
Old Nov 11, 2003 | 07:39 PM
  #862
DA-MAX's Avatar
falcongsr, whats your experience with the romulator....does it indeed lose the program if it doesn't recieve some sort of 12v power within 12 hours?
Old Nov 11, 2003 | 07:50 PM
  #863
falcongsr's Avatar
What is this crap?
Default Re: (DA-MAX)
well the battery in there seems to be working indefinitely, but i have been messing with it at least once every 24 hours lately. so i dont know. you could always hook it uop to a permanent source and it would hold it as long as the car battery didnt die.
Old Nov 11, 2003 | 11:40 PM
  #864
White Smoke's Avatar
i my honda
Global Mod
Default Re: (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">Boards are not as sensitive as people think. Remember, heat what you want soldered and then touch the solder to it. It will get sucked into place.</TD></TR></TABLE>
I would not recomend HEATING what you want solderd! In fact that is VERRY BAD!
These IC's (chips) are very sensetive to heat. Actuly, any amount of prolonged exposer to heat WILL destroy the chip or cause it to malfunction.
Just try not to leave that soldering iron on there for more than a second or two
Old Nov 12, 2003 | 12:44 AM
  #865
phresh_5's Avatar
Nobody said that we're soldering directly to the chip. I've got two IC sockets and a ZIF socket under my chip so theres no worries (even though my chip wasn't in the ZIF socket when I was soldering). Even the 74HC373 chip is on an IC socket and was placed there after the socket was soldered on.
Old Nov 12, 2003 | 03:18 AM
  #866
toxicshit's Avatar
Default Re: (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">
Just try not to leave that soldering iron on there for more than a second or two </TD></TR></TABLE>
Slashdevslashnull is right !!
im an Computer interface electronics technician. and you have to heat what you want to solder !! because otherwise it wont be a nice solder connection. and a part of your story is right too dont heat it to long or to hot !! make sure u use the right equipment. i use a digital soldering station with a temp adjustment for the right job so dont solder to hot or heat up the component to long but heat it nice enough and long enough for the solder to get sucked into the pad.
Old Nov 12, 2003 | 07:37 AM
  #867
Mr. Softee's Avatar
To the people who are emailing me their setups and asking me to make them basemaps etc.. etc..
I will not do this. You have a basemap (p72bin and p75bin). Tuning in boost is up to you. I cannot guess and nor do I want to be liable for that.
thanks
the mgmt
Old Nov 12, 2003 | 08:02 AM
  #868
riddickone's Avatar
Default Re: newest uberdata released (94goldjungsr)
Does anyone have a already modified boosted B18C bin , if so please let me know I am having trouble understanding the Fuel Hi, Ign Lo and Ign Hi setting, everything I think I have , but I dont want to screw my engine up. Any help I would greatly appreciate
Old Nov 12, 2003 | 08:51 AM
  #869
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">To the people who are emailing me their setups and asking me to make them basemaps etc.. etc..
thanks
the mgmt</TD></TR></TABLE>
Jesus, are people really that stupid?
I guess so. Nevermind.
Old Nov 12, 2003 | 11:00 AM
  #870
PHiZ's Avatar
I will.
-PHiZ
Old Nov 12, 2003 | 11:27 AM
  #871
Seraph0's Avatar
Default Re: (PHiZ)
Sweet.. I've found my engine management system!
I'm buying parts to "socket" my ECU today. And to think I've had this spare P72 sitting in my closet for years.... on me.
Can't wait to dive into this...
Old Nov 12, 2003 | 11:48 AM
  #872
ndogg's Avatar
Default Re: newest uberdata released (riddickone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riddickone &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a already modified boosted B18C bin , if so please let me know I am having trouble understanding the Fuel Hi, Ign Lo and Ign Hi setting, everything I think I have , but I dont want to screw my engine up. Any help I would greatly appreciate</TD></TR></TABLE>
read the FAQ on page 1 and you will see that it is easy to make a base map yourself.
Old Nov 12, 2003 | 01:53 PM
  #873
rjardy's Avatar
Default Re: (PHiZ)
PHIZ is the man! He knows whats going on.
Good call man.
Rob<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
I will.
-PHiZ</TD></TR></TABLE>
  #874
Mr. Softee's Avatar
LOL phiz is that good i guess.
Old Nov 13, 2003 | 11:45 AM
  #875
Mr Furball's Avatar
3 days and 30 pages later I now have learned allot about eproms, sockets, ZIF's, programs, emulator's and what ever else I downloaded on 3 floppy's.
Now I have to read a couple of web pages on how to burn the chips and figure out how to use and first what I am looking at when I bring up Uberdata.
This is my first time ever looking at a map (ROM) so I have allot of homework ahead of me. I give myself a couple of weeks to figure out somewhat of what everything is.
What would be a good eprom burner to start with and I need to buy a zif, chips(28 pin?), power source, and I guess that's it.
