newest uberdata released
Old Oct 5, 2003 | 10:51 AM
  #451
raene's Avatar
Default Re: (NateTEG95)
Which two resistors and which jumper? Thanks!
Old Oct 5, 2003 | 10:58 AM
  #452
filthy scarecrow's Avatar
about chipping, i don't know what the deal was with my ECU, but there was no place for the 1k resistor. mine is a 94 P75 ECU, and everything else went in just dandy, but there is no space marked for the resistor. anyone else have this issue with this ECU?
Old Oct 5, 2003 | 11:03 AM
  #453
T4eg's Avatar
Default Re: newest uberdata released (T-RO)
Old Oct 5, 2003 | 12:10 PM
  #454
PHiZ's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Which two resistors and which jumper? Thanks!</TD></TR></TABLE>
Dude, I already showed you in the link I forwarded you, wtf.
yeah, the P75 lacks a spot for one of the components. Honda nicely screen printed the dotted line, just fill in what you can, and it'll be fine.
-PHiZ
Old Oct 5, 2003 | 04:03 PM
  #455
Quade's Avatar
Default Re: P13 ecu (PHiZ)
Hey Phiz,
Check this out let me Know what u think. I think the P72 is Plug n Play in the prelude P13. BTW stock GSR .bin is for the P72 ecu correct?
https://honda-tech.com/zerothread?id=461838
Old Oct 5, 2003 | 04:06 PM
  #456
Quade's Avatar
Default Re: Uberdata
Also is Uberdata for USDM ecu only? I don't remember seeing any .bin files for JDM ecus.
Let me know.
Old Oct 5, 2003 | 04:52 PM
  #457
S-FLY's Avatar
So............. can anyone answer my question? Why doesn't Uberdata support ECU Control modifed roms?
Stan
  #458
bigwig's Avatar
b/c thats how it was programmed...god damn nova scotian!
Old Oct 5, 2003 | 05:03 PM
  #459
S-FLY's Avatar
Default Re: (raene)
Goto http://www.zdyne.com then goto tech section and look at the auto/manual ecu picture. Remove rp17 and install a jumper in rp18, then you're done.
Stan
Old Oct 5, 2003 | 05:04 PM
  #460
S-FLY's Avatar
Default Re: (bigwig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">b/c thats how it was programmed...god damn nova scotian!</TD></TR></TABLE>
well that's dumb, how do I run ecu control with uberdata now? hmm... hurry up and come out with a data logging/digital dash version of uberdata! hehehe.
Stan
Old Oct 5, 2003 | 05:29 PM
  #461
turbohondask's Avatar
Default Re: (S-FLY)
i was wonder i got a p28 ecu but i got a gsr motor in my car.. i was wonder what bin do i use...i got the skun2 mainfold so that is y i want to run the p28 ecu... thanks..
Old Oct 5, 2003 | 05:55 PM
  #462
red_sir's Avatar
For the guys that are already running Uberdata, are your cars still going into closed loop mode? I installed my wideband O2 in place of the stock O2 sensor and forgot to hook up an analog output to the ECU. But somehow my car didn't throw a CEL. I also had horrible gas mileage before tuning. Does this mean closed loop is disabled?
Old Oct 5, 2003 | 06:09 PM
  #463
Mr. Softee's Avatar
Default Re: (red_sir)
no, it doesnt. it should still throw a CEL w/out an o2 sensor, mine sure did
sam
Old Oct 5, 2003 | 07:09 PM
  #464
red_sir's Avatar
Default Re: (94goldjungsr)
hmm ok, I guess the p30 bin I'm using must have already had closed loop disabled.
Old Oct 5, 2003 | 07:23 PM
  #465
Mr. Softee's Avatar
strange.
sam
Old Oct 5, 2003 | 07:35 PM
  #466
Hoosier Daddy's Avatar
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Boostcreep: This program will let you make new fuel ignition maps. You make the maps with experience and research, sorry no pancea for that. Functionally, you need to burn a new map/chip everytime you make a change. Or you can use a rom emulator device, and make the changes via a laptop, without un-socketing the ecu.
-PHiZ</TD></TR></TABLE>
So there's no "realtime" tuning involved?
Old Oct 5, 2003 | 09:11 PM
  #467
rjardy's Avatar
Default Re: (Boost Creep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Creep &raquo;</TD></TR><TR><TD CLASS="quote">
So there's no "realtime" tuning involved?</TD></TR></TABLE>
nope........
rob
Old Oct 5, 2003 | 09:58 PM
  #468
twkdCD595's Avatar
Default Re: newest uberdata released (raene)
could this be used on a obd1 f22b1???
very interesting... seems simple enough, and it obviously could be much more tuneable than a afc.
Old Oct 5, 2003 | 10:00 PM
  #469
PHiZ's Avatar
Default Re: P13 ecu (Quade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">Hey Phiz,
https://honda-tech.com/zerothread?id=461838 </TD></TR></TABLE>
Sorry, this is what I was thinking of (from hondata.com): 94 and 95 Accords have EGR (A11) and the O2 heating (A6) reversed and must be rewired
I don't think that'll matter, but it might be worth investigating.
-PHiZ
gee whiz, thanks for forwarding him the same link I already did... geez
Old Oct 6, 2003 | 04:57 AM
  #470
turbodGSR's Avatar
i donated almost $150 and still havent got the 3 bar version and this was in march or something.
Old Oct 6, 2003 | 09:11 AM
  #471
raene's Avatar
Default Re: (PHiZ)
As I said in an earlier post, it's too small for me to see which resistors But thanks for your n00b-bashing anyway I'll try not to pass it on when I help out the next guy who has the same question. Don't get me wrong, I appreciate the help, but I don't like unnecessary attitude.
S-FLY, thanks for the PCB board resistor #s I'll pick up my P28 sometime this week!
Old Oct 6, 2003 | 10:05 AM
  #472
S-FLY's Avatar
Default Re: (raene)
S-FLY, thanks for the PCB board resistor #s I'll pick up my P28 sometime this week!</TD></TR></TABLE>
Not a problem dude! I completely understood what you were trying to ask, because I couldn't tell what was what from those pictures either, so I opened up my manual p28 and compared to the pics.
Stan
Old Oct 6, 2003 | 11:10 AM
  #473
Mr. Softee's Avatar
Default Re: P13 ecu (turbodGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodGSR &raquo;</TD></TR><TR><TD CLASS="quote">i donated almost $150 and still havent got the 3 bar version and this was in march or something.</TD></TR></TABLE>
email me, samurai915@yahoo.com, I will take care of you
sam
Old Oct 6, 2003 | 11:12 AM
  #474
Mr. Softee's Avatar
define realtime.
if you want emulation you can use an emulator JUST like hondata does. if you look at the emulator hondata uses, its not like they make it themselves or it has any dependence on any specific element of the Hondata control box or something. All it does is place a cord from your burner into the chip location so you can burn on the fly without having to take chips in and out. I think its pretty superfluous for $200~ that they cost. But... if you wanan say you can burn on the fly, go for it! Its useless on the dyno though and when doing street tuning imho, because you should be cooling your car down between runs somewhat
sam
Old Oct 6, 2003 | 11:17 AM
  #475
Quade's Avatar
Default USDM ecus only?
Is Uberdata for USDM ecus only? How much is a used P72 or P28 going for?
